Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:37 am)
Can't download untill tomorow but wow I am excited! Looks beautifull, I really apreciate you giving us this!!
People looking for textures: There are low-res textures at Happyland, amazing hi-res textures by Stale Loseth at Winscape 2010 and in Freestuff here by Snowsultan.
I can't find the Happyland URL :(
Loseth (bottom of page) NUDITY: http://home.online.no/~kjellil/Index-AllStuff.htm
SnowSultan VickyBuster I think at: http://www.renderosity.com/mod/freestuff/index.php?user_id=856
Also check PosetteForever which requires mebership I think but is a safe site to register at: www.posetteforever.com
Attached Link: Nod's Freestuff
Also Nod has many great med resolutions textures for Posette that now NeaP4 can useNa sai kala file mou antrea! xairomai pou sou aresei! :biggrin:
Thanks everyone for your nice comments,I hope NeaP4 will be usefull for you!
Attached Link: Yamatos JP Converter
As for joints:
Nea has some improvements over Posette but joint's centers are not moved,only some fall off zones are corrected ,so that clothes work ok.
Yamatos JP converter move Posettes joint center so that she has the minimum distortions but some clothes don't work correct,that is why he has made various poses to use those on upper or lower body depenting on your needs.
Nea as any other Posette based character can use Yamatos JP converter very well and my advice is to combine them with her smooth look :biggrin:
"-Nea’s teeth have their own texture map, you will find the texture tamplate in your RuntimetexturesnarcissusNEA Everything else is Victoria1-2 texture compatible. After you use a V1-2 MAT pose use Teeth MAT pose to apply texture to the teeth too." "NeaP4 head is mapped to accept Posettes textures" I'm confused. Both of the above are on the linked page which is titled "NeaP4" Does this mean you have to use a Posette head Tx & a V2 body Tx on NeaP4 or is the 1st statement meant to apply to regular Nea (not P4) only?
You are right it looks a bit confusing...
:blink:
So NeaP4 is a version of Nea that can take Posette, except from the teeth, that have their own map and the Lashes, that use V3 trans maps
Attached Link: NeaP4 at Planit3D
![file_354290.jpg](https://live.cdn.renderosity.com/forum/threads/2665472/file_354290.jpg)
Hello everyone!I'm very happy to announce that NeaP4 is available for free at Planit3D members area!
What's new on NeaP4:
She loves P5-P6 smooth option since it makes her look much more hi-res!
Use any of the hundred free textures that are available and change her to anything you like using the 144 original face morphs she has!!!
The pack includes a texture set and MAT poses for P4-P6
Thanks everyone at Planit3D for supporting this project,and all the people that helped me make Nea better and better with their comments!!!
pitklad
My FreeStuff
