if your working with an image you can lower the Texture_strength setting in the image node settings (it is the setting at the bottom of the node) this will lighten the texture.
if it is anything other than an image i think we would need to see a screen shot to recommend any changes
My Homepage - Free stuff and Galleries
it does make the image appear lighter and does not modify the actual image file.
it also does not change the preview. to see the affect it must be rendered.
there is also a hsv node that can be used (poser 6 only i think)
it is the last node under math
this will allow you to adjust the hue saturation and value.
Using an hsv node also means that you can plug the texture into something else at full strength. Very useful if you're using the same texture to control different aspects of a material.
PoserPro2014(Sr4), Win7 x64, display units set to inches.
www.danielroseartnew.weebly.com
hi all!
here's the deal; i'm using tabala materials in the material room and when i choose an image and want to make that image lighter (or darker) how do i do that?
right now i'm increasing the diffuse value or taking the image to photoshop and adjusting there, is there another/easier/better way to do this?
