Forum Moderators: Staff
An INJ pose INJects a morph into a figure, a REM pose REMoves the injected morph.
Morphs take up a lot of memory. So the idea is to only INJect the morphs you actually need for that figure.
For example, the Aiko 3 figure file (the .cr2 file) is about 68 megs. The Victoria 3 file is a lot smaller, around 10 megs. But when all morphs are INJected, the figure grows to around 60 megs! We're not only talking about disk space, this is the amount of menory the figure uses when in a Poser scene.
Hope this helps,
Steven.
Hello, I am new to poser and I can't seem to get an answer to the difference of an INJ figure and a REM one. They seem to be the same, but I know there must be a difference. Any help would be great. Thanks, Jim
