I love Aiko3 and Hiro3 - what a great pair of flexible figures!
Daz has shown that they intend to improve everytime. Let's hope the next gen of Mil figures is even better!
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Maybe try Netherworks
Also, it's pretty easy to scale hair to fit other figures by using the X, Y, Z scale dials. That's all "hair fits" really are I think. Once you've adjusted the scale you need to parent the hair to Aiko (even if it's conforming hair). If it's a hair found in character, use the parameter dial properties to change the parent. If it's a hair found in "hair library", change the parent by going to "object, change parent".
say." - Ghandi
where did you find the bliss hair fit? i'd love to get a hold of that.
hair fits that are only x, y, and z scales are only ok when they don't need to fit the scalp. you can spend all day scaling the koz updo or the daz changing ponytail, and it still won't fit aiko right. they're worse than clothes are in terms of needing changes to actually fit, because not only do you have to fit the exact curve of the head and forehead, but you have to fit around the ears properly too. and that's not even addressing the hair characters with the wrong jps. since bliss hair does both, well you could probably get something like a fit that had really, really obvious problems at the scalp and needed you to spend a lot of time trying to pose it so it did what you wanted and didn't collide with the body . time you'd have to take each time you adjusted aiko's pose.
i'd rather have the fit. ;D
Kozaburo's short bob hair comes with lots of hair fit poses including a fit for Aiko, which works on most hair props! :) Congrats on getting a new Lady, I like her a lot! :)
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD
7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
Attached Link: Bliss hair fit for Aiko
> Quote - where did you find the bliss hair fit? i'd love to get a hold of that. > > hair fits that are only x, y, and z scales are only ok when they don't need to fit the scalp. you can spend all day scaling the koz updo or the daz changing ponytail, and it still won't fit aiko right. they're worse than clothes are in terms of needing changes to actually fit, because not only do you have to fit the _exact_ curve of the head and forehead, but you have to fit around the ears properly too. and that's not even addressing the hair characters with the wrong jps. since bliss hair does both, well you could probably get something _like_ a fit that had really, really obvious problems at the scalp and needed you to spend a lot of time trying to pose it so it did what you wanted and didn't collide with the body . time you'd have to take each time you adjusted aiko's pose. > > i'd rather have the fit. ;DHere is the link to the fit for Bliss hair. It is found right here in the free area. It's a V3 to Aiko 3 hair fit.
DTigerwoman currently has some free nose morphs for Aiko 3 available on the front page (limited time only-AFAIK) of Poserpros
I couldn't find this the other day, but have you tried Netherworks Hairfit kits? When I first downloaded them, I thought they were a little intimidating, but if you follow the pdf instructions, they are really easy to use. He has a kit that will convert almost any major figures' hair to Aiko. (other kits are available as well)
Quote - I couldn't find this the other day, but have you tried Netherworks Hairfit kits? When I first downloaded them, I thought they were a little intimidating, but if you follow the pdf instructions, they are really easy to use. He has a kit that will convert almost any major figures' hair to Aiko. (other kits are available as well)
Wow thanks much! (Hot foots it over to download)
Cheers,
Micheál
Well I finally did it. I just purchased and install the Aiko complete set at daz. WOW what I've been missing just using the Aiko LE for so long. I think I've fallen for a new girl. Sorry V3 'ol girl but you've got competition! I love the A3 to SP morph and the A3 realistic morph is so cool. Now I need to go out and start adding stuff for A3. Yup I'm excited!! While we are on that subject where can one find some hair fits for A3 for koz hair, etc? I found one for danae's bliss hair but could some one point me to others?
Cheers,
Micheál
My Facebook Page
