Attached Link: Why doesn't hair render properly in Firefly?
Don't use texture filtering. That will make the image blurry, and cause seam problems with many textures.The link above has a lot of great info on getting the best from Firefly. I love Firefly myself, but it does have more of a learning curve than the P4 renderer.
For a final render, I usually set the shading rate to 0.05 or lower. Not 0.1. 0.01 is more like it.
Also, shading rate must be set for each item in the scene, not just in the final render settings. (This is actually a good thing. You can set different shading rates for different objects/parts, to save render time. Also, it lets you do test renders at a higher shading rate, no matter what each object is set to. When you're ready to do your final render, you can lower it in render settings, without having to tweak each object in the scene.)
Probably because you didn't change the shading rate of the objects in the scene.
Though it depends on the texture. "Noisy" or highly detailed textures tend to benefit most from lowering the shading rate to really low levels.
Another thing to try is to set the max texture size to about the same size as your render size. It's explained in the link I posted. This can help the image look sharper, without slowing down your render times as lowering the shading rate does.
IIRC, someone posted a Python script that lets you change the shading rate of everything in a scene.
But you may not want to do that. It will make rendering really, really slow. I usually set the shading rate individually. For example, hair often requires a lower shading rate than anything else, because of the kind of texture it has. A really low shading rate may be needed for a closeup of Vicky's face, but not for a full-body shot. Etc.
Lesbentley.. could you please post the texture you used? (or the whole PZ3) - I'd like to see if there's a difference between Poser 5 and 6...
(since I haven't used Poser 5 in ages and I've never had any "blurring" problem in Poser 6)
Has anyone else noticed a loss in detail between P4 and firefly rendering, even with texture filtering?
