In most cases you can just 'peel' the OBJ info out into
a separate file and replace it with a objFileGeom line.
Here's a super-simplified example... of course the real
thing will have lots of v lines, lots of vt lines, and lots of f lines.
prop soap
geomCustom
numbVerts 176
numbTVerts 696
numbTSets 696
numbElems 174
numbSets 696
v -0.031889 0.018111 -0.003103
v -0.027125 0.019807 -0.003393
vt 0.399619 0.532048
vt 0.417794 0.526865
usemtl whitestuff
f 2/1 1/2 29/3 30/4
f 1/5 11/6 39/7 29/8
Take the v's, vt's and f's out as a block, and
turn them into an OBJ file. Leave out the numbVerts
and so on. Let's say the OBJ is Soap.obj in an
appropriate folder.....
The OBJ file would look like this:
usemtl whitestuff
f 2/1 1/2 29/3 30/4
Then the upper section of
the PP2 should look like this:
prop soap
objFileGeom 0 0 ":Runtime:Geometries:DreamVillage:Soap.obj"
(Note: I have no idea why the font turned monstrous!)
My python page
My ShareCG freebies
http://hometown.aol.com/visualranger/eg-tut.html
I refer to this tutorial to extract prop geometry - but watch out that you include the curly bracket he forgets to mention in his last screen capture. It is the curly bracket just under the objFileGeom word in the graphic.
If your props are Poser 6 type and saved as PPZ files, you need to uncompress them using the python script utility first.
Eternal Hobbyist
The general habit in setting up a prop for use in Poser (via UVmapper, for instance)
is to leave out the 'vn' stuff (the normals).
So if you just copy the lines from the PP2 directly to an OBJ file, you'll have the
same "lightweight" form. But when you export the OBJ out of Poser, Poser will
re-insert the 'vn' stuff, giving a "heavier" file with info that Poser doesn't need.
My python page
My ShareCG freebies
Thanks everyone, I will try the suggestions and see what works for me ;o)
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
Quote - http://hometown.aol.com/visualranger/eg-tut.html
Thank you, Infinity10! When I went to put that tut back up I remembered someone had written to me about the error. I searched but couldn't find the letter. I didn't spot anything wrong, and put it back up. I'll try to get it fixed by tomorrow. Thanks again!
John
Just want to say Thank you again :) Downloaded your tutorial John, and it worked !
System Ram: 8GB
:biggrin:
System Ram: 8GB
Anyone got a link on how to do this? Thanks :) Dr. G?
System Ram: 8GB
