Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 11:21 pm)
Karen :-)
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Yes, its a texture....everything seems to work fine except its turning a red color.
Its a texture for Catgirl. everything applies right, just not the right colors.
I know I have to make the thumbnail, I just dont know how to make it appear as a thumbnail in poser.
'and if this is a for-sale item, please don't let the post turn into an advert, okay?'
Not sure what you mean by that.
Thanks!
Ever stop to think,
and forget to start again?
I can't help with Mat Pose Edit because I haven't ever managed to get anything to work that I tried to use it on. However I can answer one of your questions.
To make a thumbnail, you need to render an image of the item inside Poser. Set your dimensions to 91x91, render, then save the file as a .png image to the folder that contains the .cr2 or pp2 or pz2 files. Name the .png file the same as the corresponding .cr2 or pp2 or pz2 file. You can look inside any of your runtime folders to see how this is done.
say." - Ghandi
I use MPE and P6 and AFAIK have had no problems. Don't know why the texture should be red other than diffuse/ambient colours being set wrongly. Maybe you could be better downloading MPE again in case your copy is corrupt for some reason.
Sheila
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
MAT Poses I was doing with MPE recently all came out red. I had started by loading another MAT pose file rather than a character file. I couldn't get the red to go away.
Finally I started over with the character file and it worked fine. If you are loading from a pose it might be worth trying a character as the starting point.
BTW, I'd be happy to test for you if I have the required products.
Attached Link: Poser 5 Thumbnails
**Here's a very easy tutorial on making thumbnails just using Poser 5**~Nancy~
Hi, does anyone know anything about the Mat Pose Edit program? I am having a really hard time with it and most of the tutorials on the homepage for it, the links dont work!
#1. When I test out my results, my items are showing up as a different color.
#2. I cannot figure out how to make my mat appear as a thumbnail picture in poser.
#3. Need help setting up product in .zip format so that when extracted it installs correctly !
#4. When all is said and done, need someone to help test out my product so that I know it works for someone other than myself.
If there are any tuts out there I am not aware of, I would appreciate it. Been fiddling with this for 2 weeks! lol
Ever stop to think, and forget to start again?
