Sat, Nov 30, 8:38 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Adding to an existing script
IvanB ( ) posted Sun, 01 October 2006 at 6:12 AM · edited Sat, 30 November 2024 at 8:27 PM
Hi there...
I'am using the "floating Ecosystem" script and all is good...However the objects only move up an down along the Z axis no matter whats happening under them...I would like for the objects to move in all directions following the object below (in this case an ocean)..
In the actual script is states:
So, as you now have a starting point, you can try to modify this script!
Add turbulence to the instances, try to make them move, tilt them so they follow the surface of the water...
IF you havn't seen the script, this where it can be found on your pc:
C:Program Filese-on softwareVue 5 InfinitePythonScriptsEcoSystem
Can someone help to explain how to do this, as I have no idea about python scripts..
Thanks
Ivan.
IvanB ( ) posted Thu, 05 October 2006 at 3:34 AM
If your interested..check this out...
http://www.cornucopia3d.com/forum/viewtopic.php?p=25182#25182
Its a bit full on, but it might come in handy.
Ivan.
