Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Sep 08 10:25 pm)
Does it only add the actual groups contained within the obj, or does it add ghosts parts as well?
(for the less informed than Phil :) )
You'll find with cr2's that only contain the exact same groups as the obj will do strange things if they don't contain some ghost parts. I don't know if this holds true with very old figures like Posette and Dork, but on the newer millennium figures this is a pretty normal occurance.
I feel the Mac glitch is just the way the files are being writen. There is an end of line feed that is being added and for the life of me I can not see where. I'm using the same file read/save code as my other scripts but for some reason this one is not playing ball. Its almost something so small I'm just not seeing it.
As soon as I find it, it will be Mac ready
I can probably best answer the Groups/Ghost Parts question by an example:
Apollo has a ghost part in his right arm called rPectoral. It contains no geometry. The OBJ2CR2 File Converter would be able to handle that.
If someone had made a clothing item for Apollo and had included a group "rPectoral". The OBJ2CR2 File Converter would be able to handle that.
If someone had made a clothing item for Apollo and not included any groups at all. The OBJ2CR2 File Converter would be able to handle that.
If someone had made a clothing item for Apollo and included a group, "I-have-no-idea-how-to-group-models-but-I-believe-PhilC's-OBJ2CR2-File-Converter-will-sort-it-out-regardles". The OBJ2CR2 File Converter would be able to handle that.
Some models include geometry in their ghost parts, often a small sphere, so that there is something for the user to click on. The OBJ2CR2 File Converter would be able to handle that also.
Is there some tortured combination that I've not thought of? ... possibly. Will the OBJ2CR2 File Converter be able to handle it? ... most likely, and if not I'm sure that I'll be able to come up with a solution. Except for a willy warmer, there you are on your own :)
Actually thinking about it even that if you ask me nicely for a template :)
....... No don't I'm kinda swamped at the moment filling orders.
Hi Phil,
"Apollo has a ghost part in his right arm called rPectoral. It contains no geometry. The OBJ2CR2 File Converter would be able to handle that."
How would it handle that? Would it include a ghost part in the resulting cr2? If there was a bit of geom in the clothing encroaching in the space of the original figure's ghost part would it slice up that piece as the ghost part hence no longer being a "ghost" in the clothing? Sometimes I would like it grouped off, sometimes I wouldn't... can we control that?
Looks great anyway, congrats on another neat utility :)
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
In the above example the resulting Apollo clothing would include a body part "rPectoral" which would conform to and move with Apollo, (or allow you to move it independantly), but it would not contain any geometry. It would correctly perform its job of deforming the upperArm. You would be able to select it from a menu but there would be nothing to click on in the view.
There is no one "correct" set of joint parameters for any conforming clothing figure. The OBJ2CR2 converter will apply a very good set of parameters which will suit the majority of cases. Where adjustments are required these are generally going to be small. The OBJ2CR2 file set includes an on screen video tutorial explaining how Poser joint parameters work and clearly identifies and explains what these adjustments might be. Its very much a case of "Oh now that I've been shown what to do it's not as difficult as I thought".
It is the same video that is included with Wardrobe Wizard. The degree of required adjustment will be similar to that with Wardrobe Wizard.
Wardrobe Wizard will convert conforming clothing from one supported figure to another, or to a morphed version of that figure. It can also convert a dynamic cloth prop between supported figures or to a morphed version of that figure. It will apply limited regrouping, for example splitting thighs into buttocks and thighs. It can not take a non-grouped or incorrectly grouped OBJ file and make it into a conforming clothing figure.
The OBJ2CR2 File Converter does not change the shape of the model. It will correctly group the model irrespective of what groups are in or absent from the original OBJ file or prop.
Making a correctly grouped OBJ file into conforming clothing is easy. You basically edit an existing CR2 file to point to your OBJ file. The tricky or time consuming part is defining and naming the groups. The OBJ2CR2 File Converter does this quickly and simply and then applies it to a CR2 file.
Required Poser skill level:- Beginner
Required Python knowledge:- None
The OBJ2CR2 File Converter is not essential, it is a time saving convenience that can be used by a novice.
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
Having seen so many forum posts asking, "How do I make my clothing model into a conforming figure?" I though it was about time I did something about it and make it easier for folks to do. The end result is a Python script that asks the user to load the figure, import the clothing OBJ file (or load the clothing prop), add a supplied template to the scene then click a "Create Conforming" button and the job is done. The clothing is now converted into a figure which can be conformed to the figure.
Not just a simple CR2 edit, this script automatically creates the required body part groups in the clothing. Wont matter if it already contained groups, wrong groups or no groups. The OBJ2CR2 file converter will group the model as required.
Required Poser skill level ..... very low.
Required knowledge of Python .... zero.
Full details are at :-
http://www.philc.net/OBJ2CR2_page1.htm
I hope folks find it useful.
PhilC
