Mon, Dec 2, 11:21 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Compare 2 obj file to get a delta file
formoz ( ) posted Sat, 07 October 2006 at 5:15 AM · edited Sun, 01 December 2024 at 9:12 AM
Hi all Anyone Know a tool to compare 2 .obj file and result a delta file (to use as a morph injection). Typically i want to convert the cloth result obj file from Cloth Converter 2.2 and ust a tool to compare it with cloth original obj file to create a delta obj file ... Am i clear ? :P
formoz ( ) posted Sat, 07 October 2006 at 7:54 AM
Apparently Poser Little Helper (PLH) would do the trick. Going to check that :)
