You can load both figures simultaneously into Daz Studio before before transfering them. Rebooting your system and running Bryce right after helps a lot (Bryce hates fragmented memory) both in speed and avoiding crashes.
If you want to import them individually you have to "break" the DAZ Studio link on the first figure before going back to DAZ Studio, deleting the first figure and loading the 2nd. You'll find "Break D|S Link under the "Objects" menu.
Brett
Also, if your PC system is not powerful enough memory wise you can import one figure into a Bryce scene with no other objects, terrains etc and save this. Create new file, import second figure into Bryce, save this and then use the MERGE function to combine the two figures into your scene for rendering.
Of course this causes issues if the two figure are meant to interact such as kissing, embracing, dancing etc...
Hello
How to import two Poser figures (pzz) in Bryce 5,5 via Daz Studio? Each time the second one in DAS replace the first one in Bryce.I save the bryce file with the first figur e,thinking if relaoding in import the second one:no the first is stiill in Daz and if i import second it only replace the first.Some suggestion!!
Thanks
