Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 21 6:49 am)
oops, I rendered in cararra (I do nearly all my rendering there), but for some reason that made the stainless steel of the sink look funny so I should have rendered in poser. Love esther
I aim to update it about once a month. Oh, and it's free!
ZIGGIE
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
lol Ziggie! I wonder how I knew it was you! lmao!
System Ram: 8GB
Virtua36: Hopefully soon, but... estherau who is beta testing it all for me... is a hard task misstress.
Its not that what estherau is testing is faulty... just she keeps suggesting things to add to make it all look more realistic... so the set just keeps growing and growing.
pokeydots: he... he... he... prolly cos I leapt before I looked...!
"You don't have to be mad to use Poser... but it helps"
Hey Ziggie do you have blankets for that bed? She's gonna catch a cold!
System Ram: 8GB
no postwork. Love esther
Ok Just wanted to make sure she wouldn't freeze!
System Ram: 8GB
I will take care of that by adding a curved plane... textured to make it look as though the corridor continues.
I have the nasal 02 thingies covered and just need some decent reference pics of masks.
Tubing is the greatest problem of all. There are lots and lots of tubes and cables in the set but they are all static.
The overheads for Easiepose tubes is just tooo big... approx 1.5 MB per tube and thats a short one... and there are so many figures and so many possible poses it would be impossible to set up a rigid tube prop to cover them all.
I shall prolly go for a nasal tube prop that can be scaled to fit most figures with the tube draped across the chest to side of bed... but it wont actually connect to the 02 outlets.
Attached pic is of M3 with the nasal toob prop in place.
The prongs look very real. I'll get you some 02 mask pics as soon as I can. Love esther
Thanks for comments folks... all points noted... most of what has been suggested is in hand... or vein... or mouth...
As to ETA.... I don't want to commit myself, but... hopefully... in a couple of weeks. I need to put this set behind me and get onto other things... examination room... operating theatre, etc., etc...
As for hospital gowns... am looking into that... have just got OBJTOCR2 prog from PhilC Designs, so... hopefully I will be able to come up with something... unless someone makes some before me.
pokeydots: you asked about blankets..? This is the sort of thing you can get with the P6 high res square in the Cloth Room.
For P4/PPP users... I may throw in a few sheet/blanket props to cater for the more common (natural) patient poses. Similar to the one in the pic... xcept I will run it thru my modeller and add another layer on top so that it looks like a blanket draped over the sheet.
Hey Ziggie, this looks really excellent! Saw that bed on the Modo forum a while back and wondered how many Ziggies there could be in the world making hospital beds :)
I just had an idea for your tubes, I don't know if this will work but it might lead to a solution: Make a narrow, flat 2D 'ribbon' prop that looks like a snake from above (with a few bends to the left and right), but is flat from the side. Position it in plan view (one end up nose, other end over bedpan or whatever), then use cloth room to drape it downward across the bed, patient etc. Give it a displacement map which is basically just white along the middle, black along both edges, so it thickens up to a sort of 'tunnel' shape during render. Might be worth a try?
Seeing your work on this great scene might just...possibly... maybe... be the incentive I need to finish off a few of my many related props and get them into the store. I have those plaster casts (I think you beta tested them a million years ago?) and some neck braces (foam, plastic etc), a sling and so on.
Ob
Hi obm... thanxz,,,
Yup.. that was me at Modo forum... venting my frustration at how such a GOOD modelling program is ruined by the ommision of such a simple tool..
Will try out your suggestion for tubes later... personally... I don't have a problem with the tubes, because I can make them to fit exactly in my modelling programs...
The problem is... coming up with a posable tube that can be included in the product for end users.
The set has lots of static prop tubes... but it is impossible to make static tubes, wires, etc., due to the variety of figures that could be used as patients and the limitless positions they could be posed in.
I had a thought last night which I have yet to try out... a long.. fairly high def tube with lots of segments... with magnets attached at suitable distances along it.. that way (if it works) the end user could adjust the tube to suit themselves.
Sounds like a suitable problem for Dr Geep... LOL...
Yes... I did test out your Multi-cast figure and thought it was looking good... you should continue with it... I am always being asked for various casts and made a few as freebies, but they are rigid and encoded as they are made from existing figure meshes.
You should go ahead with the neck braces and sling as well... I have been asked about those a lot in the past as well.. you could package items like that together as an EMT kit or something along those lines...
ziggie
just a mention- personally, i use the free easypose tube 2.0 by ajax for all my tubular needs. i find it very easy to use. if you just make an add-on freebie texture or maybe full pose if not character (ask ajax) to group multiple ones how you'd like, you'll get the tube functionality and an opportunity to advertise through freestuff (as i notice many do). right now ajax's stuff is down (rendo is saying his bandwidth is done for the month), but i'm sure that will change. actually, i wonder why there's a run on his stuff now as his latest freebie in freestuff is more than a year old. could be anything, i guess.
MY ONLINE COMIC IS NOW LIVE
