Hi Avalonia,
Certainly a screenshot showing initial scene and imported one with the terrain flattening problem could help :)
Procedural terrains appeared in Vue5 and were not available in Vue4 Esprit (nor Vue4Pro) so, I assume it is a typo ?
If not, if you added the procedural terrains in the imported scene from inside V5Infinite, you could try saving the Vue4 scene in V5Infinite before making any modifications to it. Then work on this new file.
Hi,
I am importing a scene created in Vue 4 d'esprit to Infinite to add an EcoSystem. I stacked 6 procedural terrains to create a tree log that I placed a Poser figure into. Infinite is flattening out the terrains and the POV is shot. All camera angles and sun are the same. ANY ideas? Thank you in advance for the reply.
Regards,
Avalonia
