Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Had the D100, now have the D200 - of course with the saem lenses. The image looks a little cleaner, but not Earth-shattering.
Yes, the resolution doesn't go the way numbers might imply on the surface - the D100 (6MP) had a native res of 2000x3008, and the D200 (10MP) has a native res of 2592x3872. Just over an inch and a half larger for a 300dpi print ad - nothing to write home about.
BUT, the D200 images up-res with the Nikon capture software to 3000x4500 MUCH better than the D100 (which came out looking softer). This is mostly where these numbers in sensor MPs shine - up-resing from camera RAW images.
-Lew ;-)
(wincing) "In theory"... Supposedly you can go up to 200% before you notice any degredation...
When I did it with the D100, it got noticeably softer, so I settled on 150% and it came out better while still being able to do a 2-page spread. Haven't tested out the D200 at 200% yet - I might play with that this week, I suppose, since I hadn't thought about it until you just brought it up.
Actually, the exact dimensions for the D200 are 3000x4481 (I was using the old standard that the D100 would hit when I typed 3000 for the short side) when I up-res with Capture. It's nice and clean, and I love the exposure controls (I'm sure this is common with all OEM software converters, but it's bizzarly extensive!) better than Adobe RAW - the only downside is that I'm in a 2-stage process where I have to re-save them out as TIFs and THEN open Photoshop for the complex editing.
Haven't really gotten into Lightroom yet, as I hear you can export directly into Photoshop, so that might save some time.
-Lew ;-)
I'm such a dunce sometimes. I never thought of upsizing in Canons apps. Just tried it (from 3456 x 2304 to 6000x4000) and there was suprisingly little degradation. Nifty. Course, first I have to start taking shots worth printing ::chuckle::
I still find Lightroom really slow, even the newest Beta. I like the idea, but I'm an impatient person sometimes.
-Melen
Forgot to add this to the resolution thread below;
Many people think that a 6MP cam has twice the resolution of a 3MP cam......NOT SO!
To get twice the resolution, you need FOUR times the sensor size....so, in this case to get twice the resolution of the 3MP cam you would need a 12MP...assuming the same type of sensor in both cases.
So,for those of you with the 6MP DSLR's that may be tempted by the "new" 10MP versions....you probably won't see a great deal of resolution difference.
In youth, we learn....with age, we understand.
