Thu, Jan 9, 7:59 PM CST
Subject: Max models animated with poser?
jenxstar ( ) posted Thu, 26 April 2001 at 6:04 AM ยท edited Thu, 09 January 2025 at 7:44 PM
I recently started using poser 4 and i think that the pre-set animations are excellent.I wondered if anyone knew if it was possible to apply the animations to an imported max model that i made myself.Although the poser figures are supurb i need a low poly model for use in a game.
JeffH ( ) posted Thu, 26 April 2001 at 6:12 AM
Attached Link: http://interneteye3d.com/Tutorials/2000/Nov/PoserFigp2/default.asp
If the model is to be a figure you'd have to convert it to poser format. You can find tutorials at www.bushi3d.com as well as the InternetEye. Also, check your P4 library, there are low-poly versions of the figures there as well.
jenxstar ( ) posted Thu, 26 April 2001 at 7:04 AM
Cheers! Thanks for the info Jeff.
