Mon, Dec 2, 3:04 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 02 2:40 am)
Subject: Fox Ears vr2.0 - FREE
corinthianscori ( ) posted Thu, 02 November 2006 at 1:02 AM · edited Mon, 02 December 2024 at 2:56 AM
Attached Link: Fox Ears vr2.0
Ive posted a second version of Fox Ears (vr2.0) in the Free Stuff section.
Am in great need of feed-back from those who've used them.  Ideas for improvement or any techincal issues...please let me know!
And, I do realize I've left-out the texture and UVW map for this model. Will be releasing a texture package by Nov. 2, 2006.
Would also like  to know HOW to save Fox Ears to the Poser Library so they load already parented to V3's head. Any assistance here is appreciated as well.
NOTES
Fox Ears vr2.0
(tested in Poser 6)
Contains one Fox Ears prop, nine morphs, and one texture
UPDATES
Completely new and improved geometry!
Absolutely no mesh-ripping with supplied morphs!
No longer must Drop to Floor before parenting ears to V3!
New easy-to understand UVW map for texturing!
Prevented disco bear-attacks on press CTRL-B!
nickedshield ( ) posted Thu, 02 November 2006 at 10:14 AM
""Would also like to know HOW to save Fox Ears to the Poser Library so they load already parented to V3's head. Any assistance here is appreciated as well."" After you have the ears positioned the way you want, Parent them to V3's Head. Now, make sure the Ears are selected then have the Props Library available. Click on the "+" sign and from the popup window when asked if you want to save as a Smart Prop answer Yes. to test, move the already loaded Ears away from the head then load the saved ones. They should go to V3's head. If it worked delete the original and you are ready to go.
corinthianscori ( ) posted Fri, 03 November 2006 at 7:30 PM
Simple, and effective! Despite the VERY adequate directions you gave, I spent the last half hour making the same mistake. After following your directions, I found easy success! Brillant of me:P
Fox Ears vr2.0 load parented to V3's head now! Thank you so much for your assistance!(I'd been making the SAME mistake since I purchased P6 years ago! I thought my version had a glitch since I couldnt save anything with parented properties!)
nickedshield ( ) posted Fri, 03 November 2006 at 10:05 PM
Glad you got it worked out and thank you for making the ears available.
corinthianscori ( ) posted Thu, 09 November 2006 at 12:27 PM
Nickedshield! You're on the other forum trying out the Kenya Wolf pack!
I have decided, though to make those ears contain many more polygons next time. I know everyone can fix the bends in post-work, but I figure I'll do some tweaks and see what I come up with. Also, I'll include some extra planes for putting strands of hair ala' Kozoburo!
nickedshield ( ) posted Thu, 09 November 2006 at 12:34 PM
Hehehe, I do get around. sometimes even helpful:)
