Sat, Dec 28, 4:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: HELP!!!!
azureguardian18 ( ) posted Wed, 08 November 2006 at 3:41 PM · edited Fri, 27 December 2024 at 1:40 PM
Attached Link: Problem
Okay, I recently downloaded underdog's Jezebel to Poser 4, but I have a huge problem. Whenever I try to load the figure, this pops up
azureguardian18 ( ) posted Wed, 08 November 2006 at 3:42 PM
here's the second picture
CaptainJack1 ( ) posted Wed, 08 November 2006 at 3:50 PM
According to the text file that comes with the figure, the OBJ file needs to be extracted before you can use it. Here's the text:
Before you can use Jezebel, you need to decode her object
file using Maz's Objaction Mover program. This is available at
Renderosity in the freestuff section, and also at the author's
homepage:
<a href="http://www.sandylodge.demon.co.uk/">http://www.sandylodge.demon.co.uk/</a><br></br>
To do this, run Objaction Mover, for the Seed File,
select:
RuntimeGeometriesP4NudeWomanP4NudeWom.obj
for the difference file (again your file location may
differ) :
RuntimeGeometriesJezebelJezebel-lemurtek.pcf
Now the box above the blue arrows, where it says Figure
file (greyed out), should contain:
RuntimeGeometrieslemurtekJezebel-lemurtek.obj
Click on convert. And you should be ready to
go.
Once you have all the bits installed and decoded, you can
access Jezebel from the Libraries window in Poser.<br></br>
Hope that helps.
Captain Jack
azureguardian18 ( ) posted Wed, 08 November 2006 at 6:02 PM
Thank you so much. I could not figure out for the life of my why it was not working. Thanks again!
