Thu, Jan 9, 3:46 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: MovieMaker Object...
milamber42 ( ) posted Mon, 09 April 2001 at 9:36 PM · edited Thu, 09 January 2025 at 2:39 AM
The MovieMaker object only has methods to control Flash settings. Is there any way to be able to render a set of image files from an animation? Am I missing something??
Jackmon ( ) posted Fri, 27 April 2001 at 8:39 PM
You can use the scene.SaveImage() method and loop over the frame range you wish to render.
