Mon, Nov 25, 9:18 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: invisible clothes?
Lynne ( ) posted Fri, 27 April 2001 at 7:28 PM · edited Mon, 25 November 2024 at 7:27 AM
I'm at a complete loss. I have downloaded the Uthena dress and the WTMSdress...put everything in it's proper folders...I can see the images in the library, but when I open it either alone or with a waiting figure, it is invisible. I have checked the Object property and it says it is visible. It even has the figure circle which shows where it is, but nothing I have tried will get it to appear. I can import it as an obj and it will be visible but then it won't conform. Help please.
lourdes ( ) posted Fri, 27 April 2001 at 9:07 PM
Try deleting the .rsr in the geometries folder. Have you also checked to see if it's set to transparent in the materials settings? Lourdes
ScottA ( ) posted Sat, 28 April 2001 at 6:41 AM
With Poser3 and 4. If you don't put the .obj file in the right folder. Or don't name the folder exactly right with caps and all that. Then Poser will give you that "out of memory" error message. That means it can't find the .obj file. We asked CL to change this for the ProPack. But instead of changing that error message. They just removed it totally. So If you use the ProPack. And you make the same mistake. You will get an invisible figure like you are getting. And no error messages at all. ScottA
wgreenlee1 ( ) posted Mon, 30 April 2001 at 12:01 PM
i wiuld try doing it all over again,ive downloaded just about everything in poser that i can get and if you have a dial up and you dont get everything just right it can do weird things,just try it again and double check yourself as you do it again
