Wed, Feb 5, 10:17 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
Subject: Question about creating a "Display Only" PNG file
Pandorian ( ) posted Sat, 11 November 2006 at 8:13 AM · edited Wed, 05 February 2025 at 9:55 PM
Howdy,
I've managed to create a PNG that only displays a message (instructions) in my "Pose Library" using the following method:
"Created a png file.... opened a new blank file in notepad and entered the following lines:
version
*       number 4.0*
Saved it into my "Pose Library" giving it the same file name as I gave the "Display Only" png thumbnail but gave it a "pz2" extension so the "png" file would show up in the "Pose Library".
That seemed to work.... HOWEVER, I notice that when an actor is in the scene (M3) and I happen to highlight my "Display Only" png file and click on the "single check mark" at the bottom, that it affects M3's pose (specifically his right leg).  Is there any way of producing a "Display Only" png file (for instructions) in the Pose Library without having the "single check mark" (apply library preset) appear on the bottom of the Pose Library?
I don't know if this has anything to do with it (I don't believe it does) but I figured I'd mention it as well.  The Display Only PNG file I created, I made larger than 91 x 91 so I could get fit more text instructions into it.  I currently have it at "115 width" x "95 height".  It displays without any problem, however I don't know if this would cause problems as generally to my understanding the PNG files in the libaries are usually set to 91 x 91.
Thanks in advance
Pandorian
Pandorian's Website.... aka......
Dizzi ( ) posted Sat, 11 November 2006 at 8:27 AM
Try that: { version { number 4.0 } figure { } }
Pandorian ( ) posted Sat, 11 November 2006 at 8:38 AM · edited Sat, 11 November 2006 at 8:46 AM
Dizzi.... you've come to my aid yet again!  Thank you!  The right leg (as well as the entire figure) does not get affected "if" the Display Only PNG file is applied with the "single check mark".  Now, I know I may be pushing it, but is there any way of preventing that "single check mark" (apply library preset) from appearing altogether if someone should happen to highlight the "Display Only" PNG file?
P.S., one of the best gifts I've received thus far has been your PoseMagic2Pose product...... excellent product! Just figured I'd mention that in appreciation for your help.
Thanks again
Pandorian
nruddock ( ) posted Sat, 11 November 2006 at 10:09 AM
Quote - Now, I know I may be pushing it, but is there any way of preventing that "single check mark" (apply library preset) from appearing altogether if someone should happen to highlight the "Display Only" PNG file?
No.
Pandorian ( ) posted Sat, 11 November 2006 at 10:23 AM
Thanks nruddock.... :)
Angelouscuitry ( ) posted Mon, 13 November 2006 at 11:03 PM
What is a Display Only .PNG, what's it for, what's it do?
Pandorian ( ) posted Tue, 14 November 2006 at 3:32 AM · edited Tue, 14 November 2006 at 3:33 AM
It's basically meant for providing the user with additional instructions (IE, first load prop A, then load prop B) "without" being an "active" button. (IE, a button that will NOT affect or alter the scene, actor or prop in any way if it is pressed).
-Pandorian
nruddock ( ) posted Tue, 14 November 2006 at 1:10 PM
Quote - What is a Display Only .PNG, what's it for, what's it do?
They act as seperators between groups of items.
This idea works better for P5 and below, which don't have P6's expandable library window (i.e. just have everything in one column).
Angelouscuitry ( ) posted Tue, 14 November 2006 at 2:53 PM
Aha, thanks guys!
I figured these were just .PNGs withou associated .PZ2s, but there is code involved?  I do'nt have Poser with me right now, but does the .PNG need a .PZ2 to show up in the library, and is what Dizzi posted all that a .PZ2 needs to have in order to accompish this?
Pandorian ( ) posted Tue, 14 November 2006 at 3:02 PM · edited Tue, 14 November 2006 at 3:05 PM
The code that Dizzi provided is the actual PZ2 you would use to accompany your "Display Only" PNG.  Simply copy and paste that code into NotePad then save it with the same name you plan on using for the "Display Only" PNG, however give it the extension PZ2 when you save it.  Your "Display Only" PNG will carry the extension PNG.
And yes, the PNG and PZ2 files work as a team..... the PNG file needs the accompanying PZ2 file in order for it show up in the library.
-Pandorian
Angelouscuitry ( ) posted Wed, 15 November 2006 at 12:11 AM
Thanks, I'd been wondering about these!
