Thanks for that tip! That's exactly what I came in here to find, and lucky me, it's right at the top :D
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
It has been difficult to use hdr lighting with indoor scenes because the walls block much of the light being cast upon the scene. No matter! That's easy to get around. Select the walls in your scene and go into the materials lab. Disable "cast shadows" for the material by going to the triangle menu located to the left of the first component window: The walls will no longer block the light from entering the room. Apply an hdr and render. That's it! Here's a quick sample render to show you that it does indeed work. This room has no windows and yet the hdr still penetrates the walls:
