Thu, Nov 28, 2:04 PM CST
Subject: RE: Pasting new content into the runtime folder
tom271 ( ) posted Thu, 23 November 2006 at 6:38 PM · edited Thu, 28 November 2024 at 2:01 PM
I just bought the EF Wildlife Series Hawk and I fallowed their advice...
*"Unzip the EF Wildlife Series Hawk.zip archive and copy the
content to your runtime folder. "
*I unzipped it to a 'temporary folder in my C drive... copied it and paste it in my Runtime folder..
but I can not see it in the library...  I click that little arror and look for it under 'figure' and no dice...  I even tried to unzip it into the Poser folder and no show either...  But it does show using the Windows browser in the runtime folder
This problem has happened to another content... but I am concentrating on the Hawk...
does anyone know what I may be doing wrong....
Acadia ( ) posted Thu, 23 November 2006 at 6:57 PM · edited Thu, 23 November 2006 at 6:59 PM
When you unzipped the file to a temporary folder, did you look through the folder to see where things were being directed?
I find sometimes that when I unzip a file that it will be something like this:
John Smith / Runtime
If you deposit that into your Poser runtime, the files won't go into the runtime. They will sit in the top level in a folder called "John Smith".
It's also possible that you are pasting the unzippedRuntime  folder instead of the contents of it, into the Poser runtime, which would result in something like this:
Runtime / Runtime
Here is a picture to show you the file structure of a Poser Runtime:
http://www.daz3d.com/support/faq/index.php?id=94
Basically, what it boils down to in a nutshell:
If you are looking for a Character or a piece of clothing/shoes, in Poser you will find them in libraries/character
If you are looking for hair, you will find them in either library/character/hair OR library/hair
If you are looking for character texture addons, hair textures, clothing textures, you will find them in library/poses. Sometimes on the rare occasion, a merchant will package their textures so that they go into the "Camera" folder (.cm2 files). If that is the case then you can either apply them from there, or do what I do and change the file extension to .pz2
If you are looking for props, they are located in library/props
Sometimes you will find clothing and hair or shoes in library/props too, depending on whether the item is actually created and saved as a figure, or it was created and saved as a prop.
Figure items are "conformed" or "parented"
Props are parented.
If you are just starting, it's best to get started on the right foot. DO NOT just install files into the runtime! That will only lead to frustration because you won't be able to find anything, and not all files are packaged equally and land up all over the place.
Here is a link to a tutorial on using multiple runtimes.
http://forum.daz3d.com/viewtopic.php?t=9060&start=0
Tyger_purr ( ) posted Thu, 23 November 2006 at 7:14 PM
I just checked mine.
if you just copied it directly it will be under figures in a folder called "EF Wildlife Series"
My Homepage - Free stuff and Galleries
tom271 ( ) posted Thu, 23 November 2006 at 7:29 PM
Thank you very much for your speedy feedback.... I made special notation of your link and will study this folder system for future needs...
I did find  under the CONTENTS Tab in Poser... that there are two functions:
' *RESET CONTENT PARADISE' * and *'INSTALL FROM ZIP ARCHIVE' ... * The latter will install a zip file into a 'DOWNLOAD FOLDER'   in the Poser Library file...   You may know this folder when you are in your library Tab. at the top of the level..   I got Poser6.... Dowloads.....Poser5
By using this 'INSTALL FROM ZIP ARCHIVE' function you are instaling thing 'a new' in their own runtimes and associated file folders in the downloads folder.....
Check it out....
