Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
What happens when you click the Props button, same thing?
Have you drilled in with file browser to the Runtimelibrariesprops directory, is it still there? I can tell from the screenshot you are a Mac user, so I probably don't have too much technical help to offer, but I'd make sure the directory is still there and healthy. It may be that the hard disk has been damaged in a way that makes that directory appear empty or unreadable, or possibly your or some content management bit has moved the directory to a place you aren't looking for it.
Yes, the folder with all the prop contents is still there and in the proper place. Contents are easily viewed in the FINDER and also using MCPBrowser (a program that installs runtime Folders and fixes RSR files for the MAC). Also, I can still access the props by double-clicking the PROP FOLDER butttons and navigating that way. It's just the LISTING MENU that's not working properly.
