Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
hmm....would that happen, even if I have shadows turned off in the render? (I'm relatively new to P6...I've had 5 for years, but just got 6 in September)
into a fruit salad.
It's the skin AO causing the problem, if it's not the lights. There should be a bias setting on the AO node, which may need to be increased. To be absolutely sure, unplug the AO node and do a render without it. If they go away, then you know.
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
Ok, I'm working on some skin settings....and I did a quick test render, and there are these big splotches on the skin toward the back.
I don't have texture filtering on. I'm not using IBL or AO in lighting, but there is SSS and AO on the skin. 2 infinite lights, set to about mid-strength, grey lighting.
