Vue F.A.Q (Last Updated: 2024 Sep 17 9:46 am)
Do it. I think the Mac Pro is an incredible fast machine. I have the 2.66 MHz version with 4 GB Ram and am already totally happy. It is so far one of the fastest machines around.
The only tzhin gthat would make additional sense is to have more than one machine for rendering. Especially when you want to do animations. Then network rendering is a lot of help probably and something to think about. With Infinite (5 or 6 does not matter) you can have Winodws PCs as well in the network so not all machines need to be Macs.
And not to forget, most sense does an Intel Mac make when you run a UB version on it. Which means a Vue from generation 6.
Quote - And not to forget, most sense does an Intel Mac make when you run a UB version on it. Which means a Vue from generation 6.
I'm not sure what you mean re. the quote above - could you explain
Also - the mac would have 3 gigs + 2 graphics cards - how would that compare with your 4 gigs
Also also - we already have a G5 powermac - that could be hooked up to get faster renders?
UB means that the program is a universal binary. V6I is UB so it will run natively on the IntelMacs (MacPros), which will mean a significant speed bump compared to a G5. As wabe already suggested I'd go for the MacPro for sure. 3GB should do, however it depends on the amount and size of textures maps used.
Yes, as TheWingedOne said - Universal Binary. this means the program is optimised for Intel Macs. And indeed an incredible step forwards in performance. And i mean a really BIG step forward.
Memory i think is ok on your machine, the two graphic cards i question a little. Is this really necessary? I was unsure in this field as well and thought the same. Then i found out that the default NVidia board that is build in has already 256 MB and is able to drive two monitors without a problem. Now for rendering processor performance is key, not graphic card quality. I at the moment have a new 20“ TTF monitor as working monitor and my old 17" moinitor as second here. Is perfect for my needs.
Well, maybe for people who want to run a store with several displays more than one or two graphic cards could make sense. But i think this is only advertised because it is possible - not because it is necessary.
What i find as well very interesting on those Mac Pros ar ethe two Ethernet cards that are there - so you8 can have a network AND an ethernet printer on the machine without needing a hub.
A super interesting thing of course is the option to run Windows on that. Part of my busioness is doing PowerPoint presentations. Mostly for clients with Windows machines. Now i can do that on this machine without using an emulator and performance loss. As well for tests this is excellent - i can check wether bugs are Mac only or are Mac and Windows. For me this is brilliant. For you it might be interesting to use video editing software that only runs on Windows on this machine. Could be another interesting aspect.
I plan to rebuild my render farm (2 P4 3gHz w/ 2gb RAM each and 2 AMD 2gHz 1gb and 512 mb RAM respectively). I have found that rendering time is a fraction of what it was before. Performance manager only shows 24MB of RAM usage but 100% of CPU cycles. So I will get the most powerful processors I can afford but only 512MB each.
Either that or puchase a lot of 40 866mHz machines off Ebay (they're like $45 each).
The two macs that I will have ( the G5 one running OSX 10.3, the other macpro, the intel one, presumably running mac OSX as well ) they will be linked into a windows 2003 server ( our whole office is PC based apart from these two macs.
Will the macs work fine running togther as render farm over the windows 2003 network - or can they/should they be linked directly one to another?
Any help really is appreciated - I do the graphics, draw the pictures, but could do with knowing alot more . . . .
thanks for help so far
I'm upgrading (as soon as it gets here) to a dual athlon 5000+ system.
A few questionsbefore it arrives:
Is there a V8I 64 bit version?
Will V6I automatically take advantage of a dual core system, or do I need to make some system or preference changes?
It was listed as having windows xp installed, but it didn;t say if it was windows xp64, or just windows xp. It also looks like new pc owners with xp installed get a free upgrade to vist when it's released, and I';l probably go ahead with vista 64 when it's available.
Gareee,
There is a Vue6Infinite 64-bit version. Vue runs beautifully on a 64-bit system. I am currently running it with XP-64. The 32-bit and 64-bit are included in the current version of Vue. Vue senses your operating system and installs the right one. I'm very happy with XP-64 and have no plans to upgrade to Vista in the near future.
And Vue takes complete advantate of dual core. During renders both are running full blast. :-)
Lin
Grayhem, i think you can do both. Via network or via link the computers together directly. All it needs is a unique address for each computer. Normally an ip address. Then you define ther cows via those addresses and all can participate. As well, exactly what i am doing.
And i think you asked it before - to run Windows XP on the Mac Pro you indeed need a license for XP. But Windows XP home isn't too expensive - and this would be enough for the Mac Pro.
XP Home won't use all 4 CPUs/cores on that MacPro, it's limited to 2 CPUs/cores.
As for rendercows, if I'm not mistaken you can even install cows on some of the faster Windows machines in your network and have them work together with the Mac(s).
Intel based Macs are (probably, I don't have the data) fine and fast render machines. G5 based Macs are SLOW when it comes to Vue rendering. I've seen stats where a dual G5 2.2 was slower than a P4 2.4.
64bit is great. That MacPro looks sweet, but make sure it has enough memory. 3 Gig looks like quite a lot, but with 64bit you'll want more. Especially if you're working with complicated scenes with lots of objects, lights, hires textures and polygons.
By the way, XP Pro 64bit isn't all that expensive. I bought an OEM version for 140 euros. XP Home is cheaper, but not by much. And it's far more limited.
Thanks for all your comments
Because we thought that the G5 was the best machine on our network, and trying the rendercows network rendering before proved reasonably dodgy ( a couple of nights renders messed up ) we have been just using the G5 mac. We planned to link the new macpro up to the existing G5 to (well at least, we thought, get DOUBLE the render speed)
It looks like maybe our G5 doesn't compare very well to the macpro - is our thinking right that it would be the best to link to the macpro for network rendering?
Would you folks agree that we really need to utilize ALL of the reasonably decent machines on our network for network rendering? ( I think it was before the fix of 5.11 that we had our problems - we didn't really try after that as we had looming deadlines!!)
again, thank you for all your input - it is v. helpful
For Vue rendering I'd recommend a dual Opteron or dual Xenon setup. On a mainboard that supports at least 16 GB of memory.
If you use dual Quad core Xeons, you can have 8 cores in one machine - it'll be one hell of a renderbeast!
It'll have to be a PC running a Windows Server 2003 OS. Mac doesn't make these machines (yet).
The MacPro can have up to 16 gig ddr ram & quad core 3 ghz processors ( that means 3ghz x4, doesn't it?)
Would what you're suggesting ( SVDL ) be better than that? - I mean it sounds interesting, for we really are trying to find a fast solution
But bearing in mind we also use the mac for video editing and quite alot more
Hard to beat a Mac when it comes to video editing. Hard to beat a PC when it comes to Vue rendering. So I think the MacPro with quad core Xeon is probably the best bet.
Just a thought - how about illustrating your actual network so that we can have a better view what makes sense and what not. At the moment it is a little foggy for me.
So, how many workstations do you need/have and how many render "slaves" do you want? In my eyes this is the first step - to define the needs for let's say the next two-three years. And then try to find out how to get there.
For the machines that are discussed here i would say it needs not many render slaves really to have a really powerful setup.
AND, you can always grow. If you need a Mac for video editing AND 3D (and i guess you do not want to repurchase especially the video software for a new Windows machine) then go for a Mac Pro. Full stop, no alternative. Then, if you find out that you need more power for 3D Rendering you can add a powerful Windows machine to the toolbox, Vue for example comes with both versions, Mac AND PC so you will not need any extra investment on the software side.
I personally - and i am absolutely no network expert - found the networing of a mixed machine environment not very difficxult. Especially when you do not want much more than file exchange and backups. And i guess that is what you mostly want to do.
Thanks everybody - its really good to get feedback that helps
Watch this space today or tomorrow for a illustration of the network - don't know how thorough or exact I can make it - I know the specs of the machines roughly, but I'm sure even an approx guide might help ( I'll try to be exact! )
See what I can do!
sorry for the delay in giving illustration of our network - been v v v busy!
I suppose really what I was trying to figure out was would the Macpro quad core be a big renderspeed improvement
and it seems so
I would like to know just how much an improvement - is that what the benchmark test will tell us? - are they going to benchmark the Macpro quad core?
Everything will be benchmarked :) The MacPro is a fast machine indeed, but the best performance sweet spot right now in the high end is a Core 2 Extreme QX6700 machine, which you can easily overclock. And if you want the absolute fastest dual cpu system for rendering, you should go for a Dual Xeon 5355 (2 x 4 cores).
Quote - ...And if you want the absolute fastest dual cpu system for rendering, you should go for a Dual Xeon 5355 (2 x 4 cores).
I typed in 'Dual Xeon 5355' to google and got a site that talked of a Macpro with the possibility of having 2 x 4 cores - 8 cores ( they seemed to think that this modification they made might void their macpro warranty! )
Can a macpro legitimately have 2 x 4 cores - in effect 8 processors?
It's an off-record experiment that they did, so it is not supported by Apple. Officially, there is no 2 x 4 core Apple machine yet, but in theory nothing prevents them to build and sell one. The problem for the big names (Apple, Dell etc) is : how to justify selling a new high-end machine just a few months after the Woodcrest one, and say to recent buyers : the workstation you spent $$$$ on, just two months ago, is now obsolete, thank you ;)
If you want the Mac based machine now, I'd say go for a MacPro for both video editing and rendering. If rendering takes too much, you could add a rendernode to the network using a Windows based PC, 2x4core.
That Windows box would only be used for batch rendering, so it can do without a fancy graphics card, a $40 regular PCIE x 16 card will suffice, as will a simple monitor.
So it will likely be slightlly more expensive than the MacPro. Much more raw power, less versatile.You could even build the scene/animation on the MacPro, hand off the entire rendering process to the rendernode, and then use the Mac for some video editing while the Vue render controller runs as a modest background process, taking up very few resources from the Mac.
I suspect the first 2x4 core Mac will be VERY pricey. You're probably better off with a 1x4 core MacPro right now, and expand your render capacity as needed with (relatively) cheap PC boxes.
How much then would this Window 2x4 core machine cost (roughly)
As I mentioned (i think) somewhere else on in this thread, I work in an office with a network of about 5 or 6 semi reasonable PC's ( from Pentium 4's with a gig of ram down to celerons with 256 ram for basic office work )
Together they made pretty much no difference when we hooked them up with rendercows - the first couple of runs we did didn't work very well at all
We then went on to use ONLY the Mac G5 we have
All we are trying to get ( on the strictest budget ) is a much faster solution
The Macpro looked good, and quite a lot faster
If at some stage we have the resources to add another fast machine - or somehow expand the Macpro then all the better.
Why doesn't some PC company out there make a superfast 'renderbox', specifically designed for 3D rendering for amatuers and semi professionals - with no other features but render power? Maybe this is naive...
Quote - Why doesn't some PC company out there make a superfast 'renderbox', specifically designed for 3D rendering for amatuers and semi professionals - with no other features but render power? Maybe this is naive...
I'm not sure exactly what you are looking for but if you wish to have 8 cores you will have to get a server board. This means you will have to buy some rather expensive RAM and your overclocking options will be rather limited. If you wish to have a fast rendering PC I would suggest:
Motherboard: Asus P5B Deluxe (allows for high FSB)
Processor: Intel QX6700 (single quad core processor)
RAM: DDR2, at least 800MHz
Cooling: Water or good air (Scythe, Zalman, Tuniq Tower...)
With that setup, some luck and some testing you should be able to hit around 3.5GHz.
I have the opportunity of getting a MacPro with Quad 3.0GHZ processors, 3gig of ram, and 2 good geforce graphics card ( it can take a total of four! )
At the moment we use a G5 PowerMac 1.8dual core processor, 2gig of ram, 1 x graphics card
We are trying to spend our money in the wisest possible way to get the best render times that we can at the moment - does anybody have any other suggestions, or experience with using a MacPro
or generally any helpful comments
We are trying to do animation for video presentations, and want to get a reasonably fast workflow for producing 5 - 10 minute presentations ( some fully animated in Vue, [and blender!?] )
What's your experiance?
