Tue, Jan 7, 12:40 AM CST
Subject: Firefly Question
Anniebel ( ) posted Sun, 10 December 2006 at 4:17 AM · edited Tue, 07 January 2025 at 12:36 AM
Ok I don't use firefly much because it chokes my system, so I am not used to it.
Have been trying to render V4 with the Grace texture, but I am getting some kind of artifact.
Does anyone have any suggestions on how to fix it?
I had texture filtering off & use displacement maps, ray tracing & smooth polygons on.
Thanks
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
TrekkieGrrrl ( ) posted Sun, 10 December 2006 at 4:26 AM
Uh that isn't artifacts, that's shiny stuff.
Some of the new V4 textures come complete with Poser 5+ nodes, which means that there's likely a gloss node at the lips, that's what you're seeing there, the shine. Same with the tear material which glistens.
Probably those shiney things won't show up with the P4 renderer, which is why you havne't noticed before. I'm not sure, I haven't used the P4 renderer since I got Poser 5 back in the days L
Anniebel ( ) posted Sun, 10 December 2006 at 4:32 AM
I first thought it was something like that, but then changed my mind because it looks too harsh.
Is there any way to soften the effect?
Helen Keller
pjz99 ( ) posted Sun, 10 December 2006 at 4:37 AM
You can tone it down in the Materials room, I'm pretty sure it's just reflection.
My Freebies
Anniebel ( ) posted Sun, 10 December 2006 at 4:46 AM
Yes but how? What do I change?
Thanks
Helen Keller
pjz99 ( ) posted Sun, 10 December 2006 at 4:49 AM · edited Sun, 10 December 2006 at 4:52 AM
From memory (not in front of my Poser machine):
Materials Room -> Advanced Tab and then I believe it's a straight numeric value in the main material properties child window "Reflection".  Make that number smaller, 1.0 is "a lot" and 0.0 is "none".  It's a bit organic because it goes along with the bump map and the shinyness won't behave the same in all circumstances.
edit: ... or maybe I misremember:
http://www.renderosity.com/mod/forumpro/media/folder_8/file_361918.jpg
edit2: oh never mind that's the iris, you'd want whatever they named eyeball/lens surface (cornea? sclera?)  Iris is beneath the lens so wouldn't have reflection normally.
My Freebies
pjz99 ( ) posted Sun, 10 December 2006 at 4:53 AM
Pretty sure it would be Reflection_Value in that leftmost window "PoserSurface".
My Freebies
Anniebel ( ) posted Sun, 10 December 2006 at 5:26 AM
There is no reflection value, the node controlling it seems to be called antisophic (sic)
I have have to go to bed, too tired to play any more, will fiddle in the am.
Helen Keller
TrekkieGrrrl ( ) posted Sun, 10 December 2006 at 5:31 AM
Ah an anisotropic node and not the glossy one then.
Easy-peasy :o) Just pull the plug on it.
TrekkieGrrrl ( ) posted Sun, 10 December 2006 at 5:32 AM · edited Sun, 10 December 2006 at 5:33 AM
BTW just a curious question. The first picture in the thread here. You said it was firefly, but why is her nostrils glowing then? Or did you use the default (draft) setting? That one has shadows OFF and will give glowing nostrils as well as a lot of other artifacts, it's really not meant for actual renders, just a quick preview.
Anniebel ( ) posted Sun, 10 December 2006 at 5:37 AM
I haven't gone to bed yet LOL, now I am going.
No I didn't use the draft mode, this is the optimal setting - where the line is on the right.
I always get nostril glow, even with firefly, I have to edit it out in PS
Helen Keller
pjz99 ( ) posted Sun, 10 December 2006 at 5:40 AM
Quote - Easy-peasy :o) Just pull the plug on it.
Thanks for solving that, that was next on my agenda when I get home from work.  That's about my last major reservation with V4, the heavy gloss on the eyes.  I'm going to fiddle around with that node and see if I can get something I like, because I don't object to the wet-eyes look in itself, it's just too intense an effect for ordinary images... I expect I'll get a lot of use out of it in certain situations though, along with the Tears bit (material zone? morph? )  :)
My Freebies
KarenJ ( ) posted Sun, 10 December 2006 at 6:29 AM
Quote - I always get nostril glow, even with firefly, I have to edit it out in PS
Try increasing the size of your shadow maps, that can help tremendously, and look through the shadow cams to ensure the area is optimised.
And if you are in P6 try turning on ambient occlusion for the relevant skin areas.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
moogal ( ) posted Mon, 11 December 2006 at 3:18 PM
I just go into the group editor, and add a mat group to the head called nostrils (which obviously I do after selecting the nostril polys).  Then I copy the head mat to the nostrils, set the specular to zero and lower the diffuse a little bit.  Helps alot.
Anniebel ( ) posted Mon, 11 December 2006 at 3:35 PM
Quote - > Quote - I always get nostril glow, even with firefly, I have to edit it out in PS
Thanks, could you repeat this in English LOL - where are the shadow maps? How do I turn on ambient occlusion.
Helen Keller
SaintFox ( ) posted Mon, 11 December 2006 at 7:04 PM · edited Mon, 11 December 2006 at 7:04 PM
You find the shadow maps when you hit Object-properties for each light. Use a map that is far larger than the default 256 and readjust the Shadow Min Bias (in the other tab of the light properties). Try something smaller than 0.8. 0.6 is a good starting point, 0.5 and 0.4 give me smooth shadows, too. Lower values cause artifacts (with my preferred render-settings! May work fine with yours!).
Ambient occlusion: Just open the nostril's material in the mat room and hit the "Set up ambient occlusion" button you find on the right side. Looks good with lips, head, body... too!
I'm not always right, but my mistakes are more interesting!
And I am not strange, I am Limited Edition!
Are you ready for Antonia? Get her textures here:
The Home Of The Living Dolls
