Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Well that's what happens when one wears heels in the nice soft grass. Cool Picture Jim!!! Seal
Real soon now, I'm shooting for mid-May. It looks like the set will include: A triangle-style bikini top A halter top as above A backless cami top A G-String bikini bottom (also as above) A Micro-mini skirt A low-rise pair of jeans (which are turning out to be a ton of work, all those seams and buttons and pockets!) A tank style swimsuit A catsuit (I just put a optional keyhole in it) The pumps above A pair of thigh-high boots Plus maybe: A lower heel thong sandal A man's-style shirt (which could double as a dress) A longer slim-style skirt Accesories, a choaker at least, maybe some earrings I sort of like the symetry of 3 tops, 3 bottoms, 3 stand-alones, 3 shoes, mix and match! Incidently, the background is right behind my apartment, shot with a digital camera.
Incidently, after some more work, I've decided that the maybe will be: A thong sandal (which is actually pretty cute, I'll have a pic up shortly)- the heel morphs from 6" down to 4" (which is about as low as SMV cares to wear, in spite of her problems above! A mini-chengosam, which I making so the side slits can be filled in so she can also wear it as a top (clever, I thought!) This will be similar to the one in Freestuff, only a lot shorter. (Not the same mesh, though, I've come a long way since I did that one!) 3 Accessories (gold belly chain, choaker and "one to be named later"!) I sort like of the the symetry of 3 + 3 + 3 +3! What I want to do is have optional features for most of the stuff that can be turned off thru material poses, things like keyholes, drawstring tops, alternate belts- not just a transmapped hole, but done properly, with an edge around the hole that appears when the hole material becomes transparent.
