i posted the image again with an idea of where i mean, i think you might get an idea.
I have opinions of my own -- strong
opinions -- but I don't always agree with them.
Attached Link: Midnight
A while back I did a scene using this model, I went for a darker night time look. Lights, spot lights, etc., adds a lot to sci images. Also take a cruise through Rochr's gallery for inspiration.___
Ockham's razor- It's that simple
Ok, first of all, this has the feeling of an outdoor scene with the current lighting, which generally means shadows should remain quite sharp. However, you could try to incorporate a little bit of an outdoor feeling by adjusting the lighting.
If you can, create a sort of AO-like render. Grey everything out, no specularity, no ambience, just plain grey or white diffusion. Then light with a light-dome and render it out. Try and get the render's light as soft as possible.
If you want to go try something really hot, attempt to adjust your lights in your lightdome do cast light in the colors of the point they represent in the sky. White/yellow towards the horizon, babyblue going upwards, darker blue going to the top. Maybe adjust brightness to match up with the sun position. Kinda like simulating some HDRI. It can add just that extra bit realism, or maybe that little extra special touch.
The resulting AO-like render can be merged with your main render in photoshop, using either multiply or overlay mode, or whatever fits your wishes. Also dont be afraid to fiddle a little with the levels of this AO layer when compositing, it's a powerfull tool to adjust the look you're after. The general idea of this layer is to make the endresult look more tactile and lifelike.
If you want to make glows, draw them in photoshop. Use screen or dodge layer(s) with blurred versions of your renders. If you're looking to add specular glows to specific objects with specific materials you can render dedicated passes in bryce too. (full black material except for the specular channel).
I know all this sounds like horror to the purist brycers, but I'm a great fan of using post effects to improve an image's overall appeal.
(_/)
(")(")This is Bunny. Copy and paste bunny into your
signature to help him gain world domination.
i'm back playing around with bryce, no not bryce 6 cause i wont install it on my computer yet.
anyway here is my problem, i want to add a bit of atmosphere to this image and improve the lighting as well. truth is i'm trying to get my mind back into using bryce/D|S, so here you go.
PS: ignore POV as i'm still working on that.
I have opinions of my own -- strong opinions -- but I don't always agree with them.
