Wed, Feb 19, 3:40 AM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 16 8:08 pm)
Check out the
Subject: SILO 1.4 Question.. How to Close a Box?!
BAR-CODE ( ) posted Mon, 27 November 2006 at 10:21 AM · edited Thu, 08 August 2024 at 6:07 PM
Hi there
Im learning Silo but i think the program is great the Documentation Stinks !
I have a "cube" with one open side  and i want to close the box !
How do you close a opening in SILO ..and does anybodyknwo a real manual for this program
I feel like the programmers only have eye's for senior users ..i can't make head or tails of 90% of the tech-text used in the unsuable "help" file...
I think closing a openig should be very simple ... well
Fill hole,  does noting ... and i just cant find the way to do it :{
Thnx for any advice you might have...
Im trying to do this for 5 hours now ... so i realy how i missed the point..
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
Teyon ( ) posted Mon, 27 November 2006 at 10:47 AM
The program has a Help file that's pretty extensive,but by no means on par with a printed manual but it covers the important basics like:
Description:
      The Fill Hole (Modify > Fill Hole) command can be used to cap or fill a hole in your mesh with a single new polygon. To use it, select exactly one edge along the border of a hole, and run the command.
**Notes:
  • This is akin to selecting the vertices around the hole in order and using the Append Polygon From Vertices command.
BAR-CODE ( ) posted Mon, 27 November 2006 at 1:19 PM
mmm ok ..i dont know what im doing wrong then .. i did run the fill hole a 1000X
Thnx i'll try again...
Chris
My Free Stuff
Teyon ( ) posted Mon, 27 November 2006 at 1:32 PM
No problem. Remember, the program tells you what you need to do or what you didn't do at the bottom of the screen.
If you still have trouble send the .sia file to me and I'll have a look, maybe the edges aren't closed...
Teyon@renderosity.com
BAR-CODE ( ) posted Mon, 27 November 2006 at 1:51 PM
Well .. it worked ...
The problem was 1: me  2: no manual..
I clicked all 4 edges "like in HEX" but only 1 was needed ...
So OBI TEYON KENOBI you saved my day again :}
Thnx mister..
Chris
Chris
My Free Stuff
Teyon ( ) posted Mon, 27 November 2006 at 1:58 PM
Anytime my friend. :)
IO4 ( ) posted Tue, 19 December 2006 at 3:25 PM
You might like to try the Nevercentre site as they have a forum there where you should be able to get help if you need it. You are not alone:)
Beginners tutorials for Bryce
Bryce Arena
