Sat, Feb 1, 5:00 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Script to show the deformers
EdW ( ) posted Sun, 17 December 2006 at 1:17 AM · edited Mon, 20 January 2025 at 2:44 PM
Is there a script anywhere that will unhide just the deformers in Sydney, Simon and V4?
I need to adjust some of the mag zones, etc on some clothing and it would sure be nice to have a script to do this instead of having to go through and manually make each one visible.
Ed
Angelouscuitry ( ) posted Thu, 21 December 2006 at 7:03 AM
Just select Display > Deformers > Show  All?  You may need ot then click on a part, but trust me they'll all pop out at you.
nruddock ( ) posted Thu, 21 December 2006 at 7:39 AM
V4's deformers are set up to use an empty geometry file, null.obj.
I did manage to get the zones to appear after saving to and reloading from a PZ3, but to get the base and magnet to show up you'll need to do some text editing.
EdW ( ) posted Thu, 21 December 2006 at 1:37 PM
Quote - V4's deformers are set up to use an empty geometry file, null.obj.
That's why I was asking about a script. There's a bunch of the damn things and going through and changing hidden to 0 and addtomenu to 1 takes some time.
