Tue, Jan 28, 8:35 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: I am very new and need help for the simlple things
Remfry ( ) posted Sat, 23 December 2006 at 9:13 AM · edited Mon, 27 January 2025 at 8:46 AM
Hello,
         I have recently bought a copy of poster 6 and I am working my way through the tutorials. I have come to an abrupt stop when trying to find the two files; peper-airplane.pz3 and CLOWN01. This may seen a bit petty but I want to not miss any thing out while learning how to use this softwear. Can point me in the right direction or send me these files I would be very greatful
 Loz
DarkEdge ( ) posted Sat, 23 December 2006 at 9:35 AM
hi remfry, and let me be the first to offically welcome you.
good luck and have fun!
okay, the pz3 file is a pose file and you should find it under the poses tab, right below the figures tab. hypothetically, you can use any pose to any figure; they might look funny and need tweaking but they will work.
now the clown1 could be a figure...i'm not sure; what is the file extension(???). are these files that you downloaded or is this straight from the box?
if you are downloading content and adding to poser i would encourage you to start installing all of your downloaded content to the poser6/downloads/runtime folder...that way you can keep the "box" figures clean and happy and everything else in a seperate area.
here is an overview of the file extensions (the extensions in parentheses are the uncompressed extensions):
bum- bump map files
cr2(crz)- posable or conforming files
fc2(fcz)- face pose files
hd2(hdz)- hand poses
hr2(hdz)- hair files
lt2(ltz)- light sets
mtl- material files
obj(obz)- wavefront obj geometry file
pp2(ppz)- prop files
pz2(p2z)- pose files
rsr- thumbnails
these are not all of the files that you will be playing with, but didn't want to overwhelm you either.
hope this helps.
spedler ( ) posted Sat, 23 December 2006 at 10:36 AM
I think this is the stuff that was missing from the original P6 release. You can download it from the e-frontier site (go to downloads->updates and it's the Poser 6 tutorials update near the bottom of the page). Grab the various other updates while you're about it :-)
Steve
nruddock ( ) posted Sat, 23 December 2006 at 10:37 AM
Attached Link: http://www.e-frontier.com/filemanager/list/updates/130/132/134/?sbss=
> Quote - ... trying to find the two files; **peper-airplane.pz3** and **CLOWN01**.
These are available from E-Frontiers site in the updates for P6 (attached link should take you direct, otherwise you'll need to navigate there yourself, look for " Poser 6 Tutorial Files").
Victoria_Lee ( ) posted Sat, 23 December 2006 at 11:46 AM
Not quite true - a .pz3 file is a scene file for Poser and can be loaded with the File -> Open dialog box by locating the scene files in your Poser 6 directory.
A .pz2 is a Pose File.
Hugz from Phoenix, USA
Victoria
Acadia ( ) posted Sat, 23 December 2006 at 1:07 PM
Welcome to the wonderfully addictive world of Poser!  Here is a mini essay that I've been building on.
One thing. If you just bought Poser 6, I think you are eligible for a free upgrade to Poser 7 at this time.
A picture to show you the file structure of a Poser Runtime can be found here:
http://www.daz3d.com/support/faq/index.php?id=94
Basically, what it boils down to in a nutshell:
If you are looking for a Character or a piece of clothing/shoes, in Poser you will find them in libraries/character
If you are looking for hair, you will find them in either library/character/hair OR library/hair
If you are looking for character texture addons, hair textures, clothing textures, you will find them in library/poses. Sometimes on the rare occasion, a merchant will package their textures so that they go into the "Camera" folder (.cm2 files). If that is the case then you can either apply them from there, or do what I do and change the file extension to .pz2
If you are looking for props, they are located in library/props
Sometimes you will find clothing and hair or shoes in library/props too, depending on whether the item is actually created and saved as a figure, or it was created and saved as a prop.
Figure items are "conformed" or "parented"
Props are parented.
If you are just starting, it's best to get started on the right foot. DO NOT just install files into the runtime! That will only lead to frustration because you won't be able to find anything, and not all files are packaged equally and land up all over the place.
Here is a link to a tutorial on using multiple runtimes.
http://forum.daz3d.com/viewtopic.php?t=9060&start=0
Another tip is to never just unzip or install anything directly to your runtime. Always unzip or install to a separate folder. Then browse through the folder to have a look at the structure of where things are going and make sure that it's in "proper runtime structure" so that when you move it to the runtime, they get into the proper folders.
Once you get your files installed, the next thing you want to do is to start making things :)
Here are some great newbie tutorials that will get you through the bare basics:
http://trekkiegrrrl.dk/tut1.htm
http://www.poserguide.nimprodaction.com/issues/issue2/cover.htm
http://www.poserguide.nimprodaction.com/issues/issue3/cover.htm
http://www.canary3d.com/tutorial/3d-intro.htm
http://www.ebonshire.net/tut-posb/index.php
http://www.cooltuna.com/poser/poser-tutorials.html
If you don't have V3 figure, which is a popular figure, you should get it.  V3 Base is free at Daz3D right now
But if you want to change the look of her face and body, or use any of the available character addon packages, you need to buy the head and body morphs.
The head and body morphs are here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3008
Also, Michael 3, is available free right now too at Daz3D. Again, like Vicky, you need the head and body morphs to change the shape of his head and body. Those can be found here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3009
If you have both figures, you can get both of their head and body morphs in one package, here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3010
NOTE:  You can use the textures from the character addon packages without having the head/body morphs.
If you want to change the look of the head/body and have the head/body morphs, do the following:
Install the head and body morphs.
Locate the morphs you want to use in the "Poses" folder.
Find the set of morphs you want to inject IE:  Full Body, Full Head.... or just certain parts.
Left  click the picture
Click the Single Checkmark at the bottom of the page.
Go to your Parameter Dials and start turning dials.  (make sure that you have the part of the body you want to adjust as the active one IE:  Morphing the ears, make sure you have the had selected.
Also, you can find many, many free morphs and textures for Vicky, and Aiko, and some even for David and Michael.  So you don't have to turn any dials if you don't want to.  Here are a couple links to get you started.
http://www.renderosity.com/mod/freestuff/index.php?user_id=55140
http://www.renderosity.com/mod/freestuff/index.php?user_id=178490
http://www.renderosity.com/mod/freestuff/index.php?user_id=105158
Using ready made character addons is pretty easy.   You need to have the figure and it's head and body morph packages installed.
Load up the figure IE: Vicky
Go to the Poses folder, and instead of looking for your morphs from the packages, look for th character you want to use.  Left click the image that has INJ, click the SINGLE checkmark at the bottom and the morphs for that character's look is injected into your figure.  No dial turning necessary.  Of course if you want to tweak the settings you can, but that's not mandatory.
Next locate the textures (if the package has some). They will be usually in the same library menu as your INJ that you used.   Left click the image for the texture and use the SINGLE checkmark to apply it.  If you don't like that texture, apply another one overtop.
You can even use a texture from another package.  IE: Morphs from package A  and textures from package C.  Or morphs from packag A, texture from package C, eyes from package D, lips from package E.  the combinations are endless :)  If the packages have their head morphs seprate from the body ones, you can mix and match morphs too. IE: body morphs from package A with head morph from package D.  That allows for even more versatility.
There are lots of sites out there that has free V3 character addons, and some that have for Aiko, Michael and even David.
Hair, clothing and textures are all figure/item specific, which means:
Michael 3.0 needs hair and clothing and textures made for Michael 3.0
Victoria 3.0 needs hair and clothing and textures made for Victoria 3.0
Victoria 2.0 needs hair and clothing and textures made for Victoria 2.0
Aiko needs hair and clothing and textures made for her.
Like figures, a texture made for one hair style can only be used on that hair style.
Clothing is also specific when it comes to textures. A texture for a pair of pants, won't fit all pants... just the pants that it was made to fit. Same with all clothing items.
Sometimes you can manage to  clothing item to fit another figure by tweaking of dials and increasing or decreasing the scale percent, but that doesn't always work. Sometimes a clothing item for Victoria 2 will fit Victoria 3, but their joints are different so posing a figure wearing clothing not made for it specifically will be hard.
Some figures can share items more easily than others, here is a link that will help sort that out:
http://market.renderosity.com/mod/forumpro/showthread.php?message_id=2682279
There are 3 types of clothing:
Dynamic:  This is clothing that you use inside the Cloth room. It takes longer to work with and there is a bit of a learning curve, but it's not too bad, but the results are more appealing in that the clothing actually looks more natural instead of "posed and stiff".
Confroming- Non Morphing:  This is clothing that you conform to a figure. The clothing is made to fit the base figure.  If you change the shape of the figure you will also have to refit the clothing, which isn't always easy if there aren't any corresponding body morphs in the clothing.  Plus posing a character in positions where they are not nearly upright is difficult.  But many prefer this type of clothing over dynamic.
Conforming-Morphing: This is the same as conforming-non morphing, only there are morph dials that you can turn that have corresponding body morphs for easier fitting.  This is the preferred type of conforming clothing because it's easier to fit.
There are programs that can help fit clothing from one figure to another, or even from the same figure to one that has been "morphed up" using their morph packages.
The Tailor, which can be bought here:
http://www.daz3d.com/shop.php?op=itemdetails&item=677
Wardrobe Wizard (I use this one and it's great). It can be purchased from PhilC's site here:
http://www.philc.net/WardrobeWizard.htm
Clothes Converter, which can be bought here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3069&cat=131
Things like hair can be used across all figures just by tweaking the scaling and trans dials and then parenting the hair to the figure.
Poses are something else that can be used across most human-like figures with just a bit of tweaking to dig out a hand, or fix a shoulder.
These are all things I learned along the way and found to be valuable, so I try to pass them along because I know how frustrated I was when I first got Poser.  Hopefully you will find the information helpful.
bopperthijs ( ) posted Sat, 23 December 2006 at 5:57 PM · edited Sat, 23 December 2006 at 5:59 PM
OK, even for an oldbie: book mark!
I was wondering Acadia; do you work in a library? You have an excellent knowledge of what and where to find things.
Acadia ( ) posted Sat, 23 December 2006 at 8:09 PM
Quote - OK, even for an oldbie: book mark!
hehe. No. I'm a nurse  :)
Channing ( ) posted Sat, 23 December 2006 at 8:30 PM
Wow. Acadia, that's fantastic. That should be what is handed out at the door as everyone new comes in. I suppose the only two spots I'd add would be about morph transferring between character and clothing, and character, and essential freebie programs like UV Mapper, RTEncoder, etc. But this is great. This should be stickied for sure!
Rainfeather ( ) posted Sat, 23 December 2006 at 8:32 PM
Acadia should be renamed wiki-cadia ;)
geep ( ) posted Sun, 24 December 2006 at 12:17 PM
( click for, um, .... another image )
Looking for tutorials for Poser?
Anyone? ..... Anyone? ..... Anyone? ..... Bueller? ..... Bueller? ..... Anyone?
Try Dr Geep Studios for fast, Fast FAST relief! ;=] :thumbupboth: _____ YEAH !
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ThrommArcadia ( ) posted Sun, 24 December 2006 at 9:26 PM
Fantastic stuff Acadia!  BM!!
(I do want to point out the sad news, V3 is not longer free over at Daz :sad: )
Remfry ( ) posted Tue, 26 December 2006 at 1:37 PM
Great thanks for all the help it is very encouraging as a new poser!!
Lorraine
