Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
After a little investigating, I think the only way to avoid the extra frame popping up is to start the Chooser dialog from a Tk app.
That said, the following example shows how the annoying Frame can be killed.
<pre style="background-color:rgb(0,0,0);">
Compare line in red to tkCommonDialog.py (rest of code is the same as Dialog.show from that file).
Don't know if it's clear... but here is what I want to do.
I have created a GUI with the internal Poser interface (using XML). I need to pick a color, so I use in my code:
import tkColorChooser
((red, green, blue),color) = tkColorChooser.askcolor()
But when I do this, it also open a little window with the title "Tk()". This window cannot be closed... Is there a way to use the tkColorChooser without opening this window ?
