Forum Moderators: wheatpenny, Deenamic Forum Coordinators: Anim8dtoon
Photography F.A.Q (Last Updated: 2024 Sep 07 5:10 am)
Yep - but is it £4000 better ? :D
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
That is right...in Canada the lens would be about $9500, and the D2X is $6000. That is not really the lens I want. This is more for me...AF-S Nikkor 600mm f/4D IF-ED II
I would not change to the D2X, because even this guy said it was not as good as he thought.
My D200 is fine. After all it is the glass which counts mainly.
The way I see it right now, is I could have had that same POV, and then cropped it tight and come up with quite similar results if my settings had been the same.
A little walk closer will save me all this money.
But the seed is panted now and as I see it , there are certain material things are nice when we can enjoy them, later it is too late.
My uncle blows way more on golf each year...can you imagine?
"The happiness of a man in this life does not consist in the
absence but in the mastery of his passions."
Knowing the nature of birds such as these you will turn up with you 600MM prime and he will immediately swoop out the tree and land on a fence post not 10 feet in front of you, you will be left wishing you had brought your 70-200 from the car
live;
sea in a Sieve.
Edward Lear
Haha You are more than likely 99% right Richard. You see I saw this eagle prepping to fly out of the tree, and I quickly changed setting, while this guy had to lug his massive gear around. I got the shot...he was still trying to zero in on him. LOL.
And I bet he would have not had time for a full frame with both wings.
Some things to keep in mind about the first 2 images up there:
1 - The D2X has the ability to "crop" the image by choosinga smaller MP format. Just like the D200, the D2X has a 1.5x magnification factor, BUT when you choose 6MP on the D2X it is actually using a smaller (cropped) portion of the sensor - only 6MP of it instead of the full 12MP, at which point it becomes an even greater magnification - I think it's actually 2x (making the 400mm equivelant to 800mm!).
2 - In the 2nd shot, the exposure was for the shadows, which makes any middle tone to lighter tones go fairly light - reducing the richness of the image you see in the first shot. Had you been on the other side of the branch/sun/eagle (the sun behind you), and forced to expose for the highlights (like the 1st shot), the sky would have been a rich blue, the foliage a rich green, etc.
I hear people saying they don't like the D2x as much as they thought they would because of noise in shadows - I guess when you pack more pixels into the saem area something's gotta give, huh?
I STILL want one... >:-(
-Lew ;-)
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
