Fri, Jan 10, 1:16 AM CST
Subject: Help - REMC Athletic Male Problem!
AgentSmith ( ) posted Thu, 03 May 2001 at 11:49 PM ยท edited Fri, 10 January 2025 at 1:14 AM
When I deselect his genetalia, his whole crotch area turns invisible! The texture (.jpg) has that space painted in...uh, what am I missing here? How do I give him that Ken Doll Codpiece?
stallion ( ) posted Fri, 04 May 2001 at 12:06 AM
Try double clicking in the hip area and deselect invisible
You might as well PAY attention, because you can't afford FREE speech
AgentSmith ( ) posted Fri, 04 May 2001 at 3:48 AM
Now I have Visible hips with a transparent hole in the front where the genetalia go, OR I have Invisible hips and a penis floating in space, or what you see above. It won't make it how it is supposed to be...but, Thank You! I didn't even think of the "visable" trait in the properties box. Some strange combo will eventually get it, I hope.
Wizzard ( ) posted Fri, 04 May 2001 at 3:55 AM
cough.. check the cr2 find which obj in the geom directories is being used.. go to that dir and delete the .rsr sometimes the .rsr for the "malenudenogen.obj" will get fragged..
AgentSmith ( ) posted Fri, 04 May 2001 at 4:05 AM
Figured out what's wrong. As far as I can tell it's a glitch with the model. Under the uppermost menu options; "Figure", "Genetalia"...ya know, that option you click to either have the genetalia present or not at all...is actually controlling the hips, NOT the genetalia. The best I can do is to turn the Genetalia on...(no pun intended), so I can see the hips, and then deselect the "visable" option in the genetalia properties box...makes his crotch look like a adult love doll. Oh, well...can't truly complain, he is free. Thanks again! AgentSmith
bloodsong ( ) posted Fri, 04 May 2001 at 5:26 AM
heyas; try turning the genitalia on and off again. usually, this fixes the problem. the genitalia switch DOES control the hip (it switches the smooth hip with the 'hip with a hole' as well as the genital body part.)
maverick ( ) posted Fri, 04 May 2001 at 6:54 AM
I had the same problem using Poser Pro Pack. Are you also using PPP?
