Fri, Jan 3, 7:48 PM CST
Renderosity Forums / Animation
Welcome to the Animation Forum
Animation F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: Adobe After Effects 7 Pro (Explosions)
mhscspo ( ) posted Fri, 05 January 2007 at 8:30 AM · edited Fri, 03 January 2025 at 7:32 PM
Can anyone help me with this one: I would like to blow up(or disintergrate) an object and let it not be in the scene once the smoke and fire  has gone!
I can put the explosion effects in but I just don't know how to make the object disappear once it's been hit....
Thanks,
nemirc ( ) posted Fri, 05 January 2007 at 8:50 AM
I don't know about AF but in combustion I would simply key the opacity to make it disappear.
nemirc
Renderosity Magazine Staff Writer
https://renderositymagazine.com/users/nemirc
https://about.me/aris3d/
mhscspo ( ) posted Fri, 05 January 2007 at 9:18 AM
Ok, I forgot to mention that I am using imported video footage with everything already in place, all I have to do is insert the effects, someone mentioned "masking" but didn't expain all that was involved with it.
staigermanus ( ) posted Fri, 05 January 2007 at 9:53 AM · edited Fri, 05 January 2007 at 10:07 AM
not sure if it's the same in AE but in Project Dogwaffle's DoggyFX plugin there's animated masks and I guess in other apps too, when you want to blend a video frame for frame into another in a particular area you can use a mask. It's like an alpha channel that selectes the pixels which are eligible to receive the second video to be blended into or over the first. The mask is however not just a do or don't thing, it's not necessarily tied to being a full selection or full de-selection of the pixels. It is a weight factor (8-bit alpha value) that can indicate the percentage of blending to apply. If the value is 0 (zero) no effect occurs. If it's 255 (100%) the full blow of the incoming video is applied over the existing video. Anything in-between, and you get a partial, subdue'd effect.
You can then use an animated mask, i.e. one that changes over time. PErhaps it changes in selection topology (shape), perhaps it changes in the intensity of the selection, perhaps it changes both. At any rate, you can 'fade away' the amount of the mask letting the explosion effect in, and thus make something disappear. For example, if you do have the same scene 'without the building' (is it layered?) you can gradually superimpose the scene without the building over the pre-existing scene with the building. Gradually, or suddenly - just before the smoke lifts.
mhscspo ( ) posted Fri, 05 January 2007 at 10:03 AM
Very much appreciated and I will let you know how I made out !!
