Fri, Jan 10, 7:29 AM CST
Subject: problems with custum figure
evertschone ( ) posted Fri, 04 May 2001 at 7:21 AM ยท edited Fri, 10 January 2025 at 7:13 AM
I'm new to this forum and I have a question. I have created a custom figure in poser 4 but I can get the joints to bend good. the legs move all over the place. Now I just imported all seperate parts as props and used the joint editor to make it move good but still I would like it to be a figure.
Styxx ( ) posted Fri, 04 May 2001 at 9:23 AM
You need to use the joint editer to adjust all your joints. Also, since it is a meck, you may wat to turn bend off for each part. You can find the joint editer under the window tab :)
evertschone ( ) posted Fri, 04 May 2001 at 2:03 PM
yea you right, Now I only have joints in the legs and in the turning ball and i notiched those move quite well. Now I will put em in all body parts. thanx
Styxx ( ) posted Fri, 04 May 2001 at 4:48 PM
very welcome :) glad to help. cheers!
