Sat, Jan 25, 12:38 PM CST
Subject: Crashes when point light is used....anyone? Poser 7
SAMS3D ( ) posted Sun, 07 January 2007 at 2:54 PM · edited Sun, 19 January 2025 at 1:16 PM
I have been experimenting with the point lights, but everytime I give it a try, P7 freezes, I can close the program, looks like I can actually still click things but nothing happens and I have to control alt delete out.
What I do, open fresh scene, add one prop like a sphere or plane, add 1point light.  Move Point light......then freezes.
ziggie ( ) posted Sun, 07 January 2007 at 3:40 PM
I have had similar when I tried to add point lights to a scene. And like you say its weird.. the preview window freezes, but everything else is still active. Can even scroll through the library folders... select options, etc., but eventually have to quit out of P7 and restart.
"You don't have to be mad to use Poser... but it helps"
Cage ( ) posted Sun, 07 January 2007 at 10:01 PM
Umm... don't let me de-rail the topic, but I thought it was sort of amusing that I've been having the same problems with Renderosity ever since they changed the site coding a few months back....  Minus the point lights....  :-P
stewer ( ) posted Mon, 08 January 2007 at 2:29 AM
Since it's a preview issue, it'd be interesting to know if you have hardware shading enabled and if by any chance the problem does away when you disable it.
ziggie ( ) posted Mon, 08 January 2007 at 3:37 AM
@ stewer... I do have hardware shading enabled all the time. So will try it again later with it switched off and see what happens.
SAMS3D ( ) posted Mon, 08 January 2007 at 4:07 AM
I am not sure, is that in the preferences hardware shading?  Sharen
ziggie ( ) posted Mon, 08 January 2007 at 4:14 AM
@ **SAMS3D:
**Its in Render Settings/Preview tab
SAMS3D ( ) posted Mon, 08 January 2007 at 1:57 PM
I will go check it out.  Preview tab huh...never when there before.  Thanks, I will go try it.  Sharen
DefaultGuy ( ) posted Wed, 10 January 2007 at 6:25 PM
Hi Sharon, Is this problem still occurring for you? Does it persist if you use Stefan's request to try it with Hardware Shading turned off? Thanks, -Brian
SAMS3D ( ) posted Thu, 11 January 2007 at 4:10 AM
Well, it has not done it at all and I did not turn anything off, but I did go slower in my positioning.  Seemed to work, no crashes.  Sharen
