Thu, Nov 14, 4:26 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: joint parameters
wulfie66 ( ) posted Sat, 05 May 2001 at 4:48 AM ยท edited Wed, 13 November 2024 at 8:45 AM
does anyone know if it's possible to export joint parameters from one character to another?
ScottA ( ) posted Sat, 05 May 2001 at 6:39 AM
JP's are just x,y,z coodinates for each body parts centerpoint,endpoint,and bending zone range. They are stored in each figure's .cr2 file. So if you have a new figure that is identical in every way to an existing figure you already have. All you need to do is copy that .cr2 file. Put it in a new folder and rename it whatever you like. Then change the two .obj pointer lines in it to point to your new .obj file. But lets face it. How many times does your new figure match anything you already have perfectly? Never. So that means finding the closest match. Then editing the .cr2 to make it work. Dan Wimiles has a .cr2 utility that amoung other things. Copies those JP numbers from one .cr2 to another. But it's not free. And I don't know how well it works. ScottA
PhilC ( ) posted Sat, 05 May 2001 at 7:26 AM
Attached Link: http://www.renderosity.com/freestuffdownload.ez?uploadid=71
There is also the one by John Stallings which I would be lost without. It is in the freestuff in the Utilities section. Just click the link [![philc_agatha_white_on_black.jpg](http://www.philc.net/images/logos/philc_agatha_white_on_black.jpg)](http://www.philc.net)
bloodsong ( ) posted Sat, 05 May 2001 at 8:22 AM
heyas; make sure that cr2 edit is 5.01 NOT 5.02. the 5.02 still isn't fixed, and it will mess up your characters when you save from it.
dwilmes ( ) posted Sun, 06 May 2001 at 6:58 AM
To clear up confusion: John's text editor is CR2Editor, CR2Edit is an entirely different app. It has a manual editor, but also 50 other tools. Joint parameter transfer is a drag-and-drop -- DAZ uses it, so you can bet it works. But as Scott notes, you will almost certainly need to do some tweaking, tho not much if you pick the right CR2 to transfer from. Dan http://www.neca.com/~dwilmes/cr2edit.html Sorry Win only for software http://www.zenwareonline.com for ZenPaint and ZenTile and very soon ZenGrid and VueMaster
