Tue, Jan 14, 6:48 AM CST
Photography F.A.Q (Last Updated: 2025 Jan 14 4:01 am)
Subject: Source of decent but not expensive fiber optics?
TomDart ( ) posted Tue, 16 January 2007 at 7:27 AM · edited Tue, 14 January 2025 at 6:38 AM
I do jewelry photos at work, a spin-off of my work as a jeweler.  With no time to do differently lit photos and layered images to get the flash of gemstones and keep metal reflections to a minumum,  I think fiber optics might help do the job.
I need to have pinpoint white light, to direct "out of view" to light a stone within a metal jewelry item.
Any suggestions where to go looking for this?  Thanks.         TomDart.
TwoPynts ( ) posted Tue, 16 January 2007 at 7:58 AM
No ideas, sorry. I assume you have 'Googled' it with no luck? Have you considered bright LEDs for this application as well?
Radlafx ( ) posted Tue, 16 January 2007 at 12:40 PM · edited Tue, 16 January 2007 at 12:42 PM
Attached Link: http://www.globalspec.com/
Try the above link. They have the latest product news. Have you tried using a light tent?
Question the question. Answer the question. Question the answer...
I wish I knew what I was gonna say :oP
olivier158 ( ) posted Tue, 16 January 2007 at 2:45 PM
hello !
you can find fiber optic in all good IT shop, or IT online shop, by meter.
MattMc_3 ( ) posted Tue, 16 January 2007 at 4:16 PM
Maybe you could use some strands from a fiber optic lamp and adapt them to work? I have heard of using heat shrink to couple a few strands of fiber optics to an LED.
Matt
Fred255 ( ) posted Tue, 16 January 2007 at 5:57 PM
Have you tried those self lighting glow sticks i know they are not optic fibre but they might work
 ecurb - The Devil
TomDart ( ) posted Tue, 16 January 2007 at 6:56 PM
I have used a light tent. There is then the problem of losing the scintillation of light from a gemstone. A nice light source is needed to shine into the gem to reflect back and make the stone come "alive".  Light tents work fine for reducing metal glare but unfortuntely reduce the lively aspects of a transparent gemstone, too.
The fibers from the fiber optic lamp will work..now just to get a source of white light to feed the fibers!
The IT shop might be good bet..but to get a light and fibers together would be easier..albiet likely much more costly.
Good ideas...I will check these out.   Tom.
inshaala ( ) posted Tue, 16 January 2007 at 7:09 PM
Attached Link: Taking photo's of gems
you need LED light sources to give the sparkle btw - i remember looking into this for my work at iSold It over the summer.  You could probably manufacture one of these if they are above your budget - just get a ring of wood, a battery pack, some wires and some of those LEDs and there you have it...
"In every colour, there's the light.
In every stone sleeps a crystal.
Remember the Shaman, when he used to say:
Man is the dream of the Dolphin"
Rich Meadows Photography
TomDart ( ) posted Tue, 16 January 2007 at 7:27 PM
I believe the fiber optic will be needed for very fine point source...considering some gems will be 4mm or so, some larger depending on the stone.   The white led would probably provide a good feed for the fiber.   Good thoughts!  I am handy enough to put it all together.
This shot is of a piece in progress. The photo shows problems with lighting, in this case,the gemstones are blown out from too much direct light. The metal is not very reflective at this stage of the work.
The second shot is more decent, still, we rejected this one since the center stone was a bit too lively and focus was not dead on.   Both pics are rejects but kept as reference to the job done.
I wanted to post one where the metal was great and the stone looked dead...alas, not on this pc!
TomDart ( ) posted Tue, 16 January 2007 at 7:28 PM · edited Tue, 16 January 2007 at 7:32 PM
The more decent shot with slightly misangles  light on the central diamond but focus a bit off is the problem here.  I will post one with a "dead stone" but that will be later when I locate the pic..likely from work. Then you will see just what the problem really is.
Light tents, etc. do work fine especially with paper things moved around to control reflections..on metal, that is.  Still, the stones will come out dead and not sparkle.   The led and fiber seems a good bet.
This shot was taken with a flourescent lamp with tissue as diffuser(down and dirty work!).  Ambient room light lit the stones and fortunately did not reflect too much on the metal.
TomDart ( ) posted Tue, 16 January 2007 at 7:53 PM · edited Tue, 16 January 2007 at 7:58 PM
Ok, this one shows several defects, first was the choice of red in the bg and the support stuff for the ring showing..but that is not the lighting probs concderning me.  The central gem is a fine emerald and a point source of light would possibly show the returned light from inside the stone better. The side stones at the bottom are dead..no light there.   This is not the best example of what I mean but does give a clue.
Please disregard the dof problems in this particular shot and note the lack of light on the bottom stones, lack of sparkle from the center stone and the still present problems with reflections(black looking areas) of the metal.(Reflections are pretty much under control now, not as in this old shot.)   This was also shot with the down and dirty flourescent with tissure diffuser.  We do not have a photo set-up. It is make do as you can.
Thanks for bearing with me on this thread!         Tom.
bclaytonphoto ( ) posted Tue, 16 January 2007 at 9:19 PM
Fiber optic cable is fairly cheap...it's the light emitter that's expensive..
www.bclaytonphoto.com
bclaytonphoto on Facebook
TomDart ( ) posted Tue, 16 January 2007 at 9:31 PM
pushinfaders, that is exactly what I have discovered...light sources are costly.  Most ready made ones are more science directed than I need.  I don't need really bright light but without experiment don't know what to expect.  I might try some white leds or go to a zenon lamp and some homemade rig to see what happens.  The main point is "point source" and small at that.   We will see.....
The one at work is for a spectroscope..but the beam is much too wide for photography, even with all the fine controls provided for color, intensity, etc.  That one won't cut it.
I might be on the wrong path altogether but fiber seems the way to get a fine point source of light, easily positioned and tiny as needed.          Thanks.       Tom.
bclaytonphoto ( ) posted Tue, 16 January 2007 at 9:32 PM
Here's a few links ...
http://store.tabletopstudio-store.com/index.html
The LED light they show is an idea..one could probably make something like that..
http://store.tabletopstudio-store.com/dida50ledbu.html
Some interesting tips here..does talk about fiber optic lights..I like the three light idea
http://www.ganoksin.com/borisat/nenam/light.htm
OK. try to Ignore the annoying blinking text..
http://www.jewelryphotography.com/index.htm#Photography
MattMc_3 ( ) posted Tue, 16 January 2007 at 9:40 PM
Here is a quickly little drawing on how you could attach the fiber optic strands to the LED's. The fiber optic strands are red, the LED is blue, and the heatshrink is green. You could drill a little hole in the end of the LED just about 1/16" deep (a few mm's), superglue the strands of fiber optic into the hole, then to help secure everything slide a piece of heatshrink over the whole thing and heat it up.
If you are going to try this or inshaala's suggestion, you must put a resistor inline with the power source (battery, power supply, etc) and the LED so the LED doesn't burn out. The value of the resistor will be determined by the voltage of your power source and the current rating of the LED that you have chosen.
Matt
Radlafx ( ) posted Tue, 16 January 2007 at 10:36 PM
Attached Link: Fib-Opt
I think you need soft lighting for certain jewelry. LED's are getting cheeper these days. If you go to the link I posted (before) you can search for manufacturers that sell them cheap. OK, here is another link. http://optical-components.globalspec.com/ProductFinder/Optics_Optical_Components
TomDart ( ) posted Wed, 17 January 2007 at 7:22 AM
Wow. I do appreciate the links and how-to illustration for led/fiber optic strands.   On the way to work now and will search this stuff out this evening.  The ganoksin article is not a bad one..I am a member of that site but didn't see this page.  The "drop shadow" box the man uses is not a bad idea at all...that is certainly worth trying.        Tom.
LouLouBell ( ) posted Sun, 21 January 2007 at 5:48 PM
Hi,
The fibre optics on xmas trees and fibre optic display balls work great.  I just cut them off with scissors and shine a realy bright (but small lens) LED torch though the back.  It shines real well as a pin pont. I know you can buy bundled cable fibre optics from some big computer stores too!!  Godd Luck, Louise
MattMc_3 ( ) posted Sun, 21 January 2007 at 6:06 PM
I forgot about the fiber optic cables used in audio systems (for "optical" digital outputs). I have bought a couple of these cables for a few dollars whenever I find them on clearance.
Matt
TomDart ( ) posted Sun, 21 January 2007 at 10:00 PM
Thanks for the last two posts...I found Radio Shack has an audio 6ft. for $14US.  Haven't checked the tree ornament/display items yet.   Looking good!    Thanks!
When the setup is done and I get some photos, I will post to show how it works(or doesn't).
Tom.
inshaala ( ) posted Mon, 22 January 2007 at 10:30 PM
didnt read much of the past few posts coz it is late - but a thought just struck me: black shiny vinyl.  You get an amazing reflection and it looks so classy if you use it as the surface you take shots of rings or any jewelry on.  I didnt manage to get some for my shots but saw some examples using it and it makes the thing look great... might want to give it a try - but if the doorknob "rustic" backdrop look is what you are going for then i suppose it isnt really useful :)
TomDart ( ) posted Tue, 23 January 2007 at 7:08 AM
I have used slightly reflective surfaces before and the effect is nice. As for the highly reflective vinyl, I can see lighting control being especially important but the look, I imagine, would be very upscale.  Not a bad idea at all.
