Wed, Jan 15, 12:40 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
Subject: Injecting morph channels
klozen ( ) posted Tue, 16 January 2007 at 6:41 AM · edited Thu, 15 August 2024 at 6:27 AM
I need to create blank morph channels in a cr2 {V3}
As a understand this V3 has 30 PBMDC and 30 PBMCC blank channels allready
What would be the best way to create new channels?
Creating more PBMDC or PBMCC channels?
Creating MIC channels ? { injection magic }
Are these channels name sensitive or can you name them whatever you like ?
Is there a limit on the amount of channels ?
Jules53757 ( ) posted Tue, 16 January 2007 at 10:13 AM
I dont't think, that there is a limit. The problem is, you have to provide a cr2 with the new channels. In this case you can even use your own names for them. There is a V3 cr2 around, I think it's for the NGM, with 80 morphchannels.
Ulli
adp001 ( ) posted Tue, 16 January 2007 at 11:25 AM
ADPmovechannel_v101.zip
(Stand alone program, works without Poser)
Not directly related to the problem in question (adding new channels is not possible with this version). But it may come in handy if you need to move or rename existing morphchannels.
I did it because I had several morphsets using the same channels. So it was not possible to load them all at once. Now it works :)
klozen ( ) posted Tue, 16 January 2007 at 1:49 PM
**Jules53757,
Thanks for your reply
**adp001,
**The problem you discribe is the reason why i have to create new channels,
I have 3 conflicting morphset's so i tried to download your program to fix the channels.
Does your program needs "aditional files" , i can't seem to open the program { windows xp pro}
Gretings**
adp001 ( ) posted Tue, 16 January 2007 at 3:01 PM
No, no additional files needed.
In the first input enter (or select) your Poser installation path (c:ProgramsCurious LabsPoser 6, for example - do not enter "runtime")
The next to fields are relative to this Poserpath.
After pressing START, it may last a minute (depending on the filesize). Watch the statusline. The program analyses the file and a new dialog will pop up where you can modify the channels.
RAMWorks ( ) posted Mon, 12 February 2007 at 10:08 AM
I need this ZIP and it's nowhere to be found now.  Can you please repost it?  Thanks much
Richard 😄
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
adp001 ( ) posted Mon, 12 February 2007 at 10:54 AM
You'll find it on my Python page. See links below.
RAMWorks ( ) posted Mon, 12 February 2007 at 11:05 AM · edited Mon, 12 February 2007 at 11:07 AM
Thank you very much!!  😄
Ah but I see this is for pz2 and not cr2's.   Thanks anyway!! 😄
My Store is HERE
adp001 ( ) posted Mon, 12 February 2007 at 11:54 AM
Works with CR2 too.
RAMWorks ( ) posted Mon, 12 February 2007 at 1:39 PM
Oh, well it's not obvious.  This is more a DAZ Studio issue in any case.  As it turns out getting Davids' new eyebrow prop for Victoria 4 to superconform and work along with Victoria's morphs as the dials are spun was a bit question mark for many of us.  DavidGB has dove in and is helping us get it resolved.  I was thinking by taking a version of the cr2 with all the channels there but the morph info removed and the needed morphs moved over from V4's head morphs would fix it but as it turns out the code is a bit different internally to get the prop to superconform and work as expected in both Poser and Studio.  Looks like a fix is on it's way.
Thanks for your help, I might have use for this tool at some other point!  😄
My Store is HERE
