Wed, Nov 27, 6:33 AM CST
Subject: Question about .mz5 format
Black_Star ( ) posted Fri, 19 January 2007 at 2:58 AM · edited Wed, 27 November 2024 at 3:56 AM
Hy there!
I have a few materials in my Runtime that are .mz5 instead of .mt5 and I canot open them in any text editor.They are a compressed form of .mt5 (this will explain why they look uninteligible in texxt editors)?If yes , how can I decompress them , so I can see what's inside in a text editor?
Thank you in advance!
Best regards!
AntoniaTiger ( ) posted Fri, 19 January 2007 at 4:15 AM
If you have Poser set to save uncompressed, just take a primitive prop, go into the Materials Room, apply the material, and then save it under a new name. I think they use the gzip format, so opening it in a compatible compression utility will reveal the underlying file.
thefixer ( ) posted Fri, 19 January 2007 at 5:10 AM
Just run the python script inside Poser to uncompress your files then you can open them in an editor.
Injustice will be avenged.
Cofiwch Dryweryn.
Black_Star ( ) posted Fri, 19 January 2007 at 7:14 AM
And where I can find that plugin?
I have searched for it in my Rutime and didn't find it.
thefixer ( ) posted Fri, 19 January 2007 at 7:33 AM
If Poser7 it's under scripts in your top menu bar!
Poser 6 I can't remember and I'm at work now so can't look, but again it's in your top menu bar then this path:  /Utility/uncompressposerfiles
You might want to also check the delete compressed files after uncompressing also, there's another tick box that I always do as well but again I can't remember what it's called, Sorry!
I'm having a bad day!!
Cofiwch Dryweryn.
Tyger_purr ( ) posted Fri, 19 January 2007 at 8:01 AM
in p5 and 6 it is in the python buttons under "utility funct"
thefixer:  the other check box is (un)compress OBJ files.
this really nice if you compress your whole runtime like i do.
My Homepage - Free stuff and Galleries
thefixer ( ) posted Fri, 19 January 2007 at 10:06 AM
Ah! I'm the other way, I Uncompress mine each time I install new stuff!
I have a massive HD so space isn't an issue! [LOL].
Cofiwch Dryweryn.
gillbrooks ( ) posted Fri, 19 January 2007 at 10:08 AM
Or you can rename the mz5 extension to .zip and then decompress it with winzip or whatever you use
Gill
Black_Star ( ) posted Fri, 19 January 2007 at 11:41 AM
That was gill!
Thank you!
gillbrooks ( ) posted Fri, 19 January 2007 at 5:09 PM
Gill
