Tue, Feb 18, 6:59 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Seamless texture fron non-seamless?
seedpress ( ) posted Sat, 05 May 2001 at 11:52 PM ยท edited Mon, 03 February 2025 at 1:37 AM
I want to scan a texture (non-seamless surface)and then turn it into a seamless texture for use in Poser and Bryce. Does anyone know of a program (or an algorhythm) that will do this?
bushi ( ) posted Sun, 06 May 2001 at 12:07 AM
It depends a lot on what 2D program you're using. If you have PhotoShop you can find tons of plug-ins to do stuff like this. A simple google search for 'photoshop plugins' would be a good start. The PhotoShop plug-ins should also work in PhotoPaint and Paint Shop Pro.
whoopdat ( ) posted Sun, 06 May 2001 at 12:52 AM
Paint Shop Pro actually has a built-in filter to do that for you. I'm not sure how well it'll do it, but it's there (Selections --> Convert to Seamless Pattern).
steveshanks ( ) posted Sun, 06 May 2001 at 2:48 AM
heres a tutorial on how to do it ......Steve http://interneteye3d.com/Tutorials/prev/3DtexturesTut/default.asp
elgeneralisimo ( ) posted Sun, 06 May 2001 at 10:58 AM
Painter has a seemlees function built in as well.
Staale ( ) posted Sun, 06 May 2001 at 12:37 PM
you can do it by hand if you want, cut the texture into four parts like this: 12 34 and flip the parts around so that the outer corners meet in the middle 43 21 the outer edges are now aligned and you only have to fix the inner borders between the parts. BTW: Line shifts does not work in the Preview! Staale
