Fri, Feb 7, 11:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: Multiple downloads
Marque ( ) posted Thu, 25 January 2007 at 5:41 AM · edited Fri, 07 February 2025 at 11:00 AM
I found a registry hack a while back that allowed you to download more than two files at the same time with explorer. Not a program to break up your downloads one that allows more than one download at a time. Anyone know where I can find this again?
Thanks
Marque ( ) posted Thu, 25 January 2007 at 6:07 AM
Found it. Now I'm not stuck with downloading only 2 at a time can do up to 10.
thefixer ( ) posted Thu, 25 January 2007 at 7:38 AM
Sounds good, care to share it with the rest of us!!
Injustice will be avenged.
Cofiwch Dryweryn.
Marque ( ) posted Thu, 25 January 2007 at 8:05 AM
Make sure you back up your registry first.
Take a minute to follow these directions before proceeding any further. Once your registry has been backed up we can begin.
As with most modifications, you should make sure that no other applications are running, especially Internet Explorer. Now, by following the simple procedure outlined below, you'll be able to increase your number of simultaneous downloads from 2 to 10.
Click on the Start button and select Run
On the Run line type Regedt32.exe and hit Enter. This will launch the Registry Editor
Locate the following key in the registry:
HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionInternet Settings
Click on the Internet Settings Key. Now go to the Edit menu, point to NEW, and click DWORD Value
Type MaxConnectionsPer1_0Server for the name of this DWORD Value
Double-click on the MaxConnectionsPer1_0Server key you just created and enter the following information:
Value data: 10.
Base: Decimal.
When finished press OK
Repeat steps 4 and 5. This time name the key MaxConnectionsPerServer and assign it the same values as indicated in Steps 6
Close the Registry Editor
That's all there is to it! If you modified your registry settings correctly, you should now have the capability to download up to 10 files simultaneously.
Marque ( ) posted Thu, 25 January 2007 at 8:07 AM
I restarted my computer and it works great! Hope someone else can use it. I use other browsers too, but mainly IE so it was a real pain to be limited to 2 files after being able to download up to 10 at a time...lol
thefixer ( ) posted Thu, 25 January 2007 at 8:25 AM
Yes it is a right PITA! [LOL]
Thanx for that, I'll give it a go when I get home from work!
Cofiwch Dryweryn.
Marque ( ) posted Thu, 25 January 2007 at 10:59 AM
lol I also use the word pita, almost renamed my dog Pita when we had problems housebreaking her
dbowers22 ( ) posted Thu, 25 January 2007 at 11:11 AM
So what's the advantage of using Internet Explorer to download files over using Firefox?
I hardly ever use IE anyway, because Firefox is easier to use in general, and less prone
to picking up trojans, worms, virii, etc.  And I have never encountered any download
limits with Firefox.
thefixer ( ) posted Thu, 25 January 2007 at 11:26 AM
Prolly none at all, but I like using IE7 that's all!
Bill gates is a God!!  ;-^)
Cofiwch Dryweryn.
Acadia ( ) posted Thu, 25 January 2007 at 12:31 PM
Yep, I've been doing that for years.
Marque ( ) posted Sun, 28 January 2007 at 8:26 AM
Yup same here. I like IE and this is just one limitation that has been fixed.
