Sun, Feb 2, 5:43 PM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Are you up to the challenge??
Subject: Adding signiture to vue5 scenes with photoshop
MadMyke ( ) posted Mon, 29 January 2007 at 9:01 PM · edited Sun, 02 February 2025 at 3:42 PM
I've been trying to add my name and copywrite notice to my vue5 scenes, I was told I can do this with Photoshop. I have no experience with this program. Can someone please give me some pointers? Or links to some tutorials?
Thanks,
Michael
MadMyke ( ) posted Mon, 29 January 2007 at 9:02 PM
Victoria_Lee ( ) posted Mon, 29 January 2007 at 10:06 PM
Open the render in Photoshop, click on the text tool, choose your font and type your signature.  It will come in as a separate layer.  Apply a style if you want and then Save for Web.
Pretty simple really.  Just like adding a sig in PSP.
Hugz from Phoenix, USA
Victoria
MadMyke ( ) posted Tue, 30 January 2007 at 12:14 AM
Thanks V!
Hawkfyr ( ) posted Tue, 30 January 2007 at 12:23 AM
You might also create the signature as a separate file. That way you could concentrate on just that.
For example...you could write your handwritten signature on a piece of paper.(White paper with no lines...Printer paper would likely work fine).
Then scan it at a high resolution and DPI into PhotoShop (300 dpi, or higher)
Select everything that is NOT part of the signature by going to Select_> Color Range...and use the Eyedropper to select the white areas (This will enable you to make sure the white inside closed letters like "B,P,O,R,Q,D" would be selected as well.
Make sure the layer is unlocked, and hit the Delete key.
Now you should have your signature remaining with a transparent background.
Now is the time to add layers and layer effects,blending modes...recolor it or whatever. (Make it yours)
Save the .PSD file and name it sig_hi_res.psd or something similar.(This will be the version you would use for Print)
Now...go to Image--> Image Size... and Uncheck the Resample Image box and reduce the Resolution (dpi) to 72. pixels/inch and click OK.
The image should get smaller.
No go back into Image> Size  an Re-Check  the Resample Image box to un ghost the sizes and make sure the Constrain Proportions box is checked...Now...resize the image to an appropriate size in the width or height boxes under the "Pixel Dimensions:" section.(this..you will likely have to play with to get right). Click OK and see if you got the right size**...if not...**undo it(CTRL+Z) and go back to resize it again.
When you got it right.. Be sure to select "SAVE AS.... and rename the file to sig_lo_res.psd.
Now...SAVE AS again...and simply name this on sig.psd
Keep this file in an easy place to get to because it will be the file you apply too all of your renders
Open your render and do any post work or what ever...then..before you save it...open up the sig.psd file and make sure the "Move" tool is selected and simply drag the sig image onto your render.
Place it in a good spot on your render... resize it if needed (Edit__> Transform) and adjust the opacity of that layer (Yes...dragging it from the sig.psd file will automatically create a new layer)
It will preserve it's transparency this way...even when you save the render as a .jpeg.
Save for web and your good to go.
This method assures that your signature...logo..or whatever you use..will be consistent on all of your renders. (Also known as Branding)
When you go to close the sig.psd file... or go to close PhotoShop and you are prompted to save it...be sure to select NO...just in case you inadvertently changed it...
But..Have no fear if you do**...remember..you saved the sig_hi_res and sig_lo_res files as .PSD files before**.
NOTE:
You could also save the sig.psd files as a .gif file so long as it falls within the 256 colors that .gif supports....The .**gif format...**as we all know...supports transparency...and will keep the files "weight" smaller than .psd...You could also use .tiff,.png or any other format that supports transparency.
Whatever you do...DO NOT save the sig file as a .jpeg.
Hope this helps a bit.
Tom
“The fact that no one understands you…Doesn’t make you an artist.”
keenart ( ) posted Tue, 30 January 2007 at 1:30 PM
I have used several methods, similar to Tom’s technique. One additional method beyond using Digimarc, is to create an additional logo so small it cannot be found without a magnifying glass. It can be Vertical, Horizontal, Diagonal, or perhaps another arrangement.
I have used a second smaller 1 or 2 point type copyright logo, added to the image at coordinates in pixels I record in a text file for later proof.  The color should be very close to the image background, and barely visible at 1200 DPI or larger view.
Image Title: My Image
Image size: 1000 x 1000 pixels
Logo: My Name
Size: Ariel Narrow, 1 point.
Arrangement: Circular
Location. 800 x 900 pixles
You can make this an easier technique by creating an Action within Photoshop. You might change the location from image to image.  Remember to do all of this work after the image has been modified, otherwise resizing and compression will destroy the small logo.
jankeen.com
