Mon, Feb 3, 7:46 PM CST
Subject: Reflection Studio guy! Help Please!
jjroland ( ) posted Thu, 01 February 2007 at 4:32 PM · edited Mon, 03 February 2025 at 7:43 PM
For any familiar with it, I am in the process of making a 'Hadouni' animation as a gift to my Eastern Dance instructor.  I wanted to use something I saw on these forums a couple weeks back that was labled Fun in the Reflection Studio.  So I copied his settings, as far as I could tell to the T - BUT I have no floor or walls.  (though the reflection is there).
I am just a beginner in Poser so I understand this is not spectacular, just wanted to do something I knew she would get a thorough kick out of.   So can anyone help (Mr.  Reflection Studio guy if you see this or anyone else)  I'd very much appreciate it.
Thanks.
I am:  aka Velocity3d
ashley9803 ( ) posted Thu, 01 February 2007 at 10:43 PM
Settings will give you the ground reflection (which you've done very nicely).
You will need props or figures (characters) for floor or walls. Settings will not give you these.
In Free Stuff you'll be able to find some floors/walls/rooms to build up a scene.
Make the ground invisible in Properties, build your scene and apply the reflection setting to the floor of your "room". I also suggest you turn off shadows for you lights if you are using infinite lighting, as the walls (& floor)  will block your lights. Better still, turn off shadows for your walls. You could put spotlights inside  your "room" for lighting but you'll need to know how to set them up properly.
Good luck, you're well on the way.
EnglishBob ( ) posted Fri, 02 February 2007 at 4:33 AM
Attached Link: http://www.morphography.uk.vu/dlprop.html
I have a basic backdrop box at the link, if you need one. I give it the most use out of anything I've ever made, I think. ;)
ashley9803 ( ) posted Fri, 02 February 2007 at 6:54 AM · edited Fri, 02 February 2007 at 6:56 AM
EnglishBob, if this is your stuff then **Thank you!
**I have used so much of it in my renders.
You are so generous with the "free stuff" you have made and it's all good.
Quite unique really, the stuff you really need for a realistic scene, that nobody else has.
My hats' off to you Bob. Hope things are cool for you in the UK.
jjroland ( ) posted Fri, 02 February 2007 at 8:52 AM
Thanks very much for the advice and the link = )
