Sun, Feb 2, 12:45 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: All right, all right... What's goin' on 'ere, then?
Morgano ( ) posted Fri, 02 February 2007 at 6:52 PM · edited Sun, 02 February 2025 at 10:02 AM
I used Wardrobe Wizard, to make Renapd's "Lilith Armour" for SP3 Sydney-sized.   On the whole, it looked pretty good, but there was a minor flaw visible (this is NOT poke-through).
Morgano ( ) posted Fri, 02 February 2007 at 6:54 PM
This is a close-up.   The small pale areas are somehow displaced from the armour's texture.
Morgano ( ) posted Fri, 02 February 2007 at 7:01 PM · edited Fri, 02 February 2007 at 7:02 PM
Now look what happens when I try to give poor Sydney anything other than the basic "scarecrow" pose.   Ordinarily, I'd associate this sort of thing with the setting of IK.   I've set this up with and without IK switched on and it makes no difference.   I have closed the file and re-opened:   no change.   I have close Poser and re-opened:  no change.   It does show up very clearly in the render, so it's not just some amusing Preview quirk.    As a test, I loaded the armour on to SP3 (default) without any problem.   That made it look like a WW problem.   Then I tried a customised SP3 set, that also required WW, and the result still worked perfectly, so I don't think that this is a WW issue.    Does anyone have any ideas, please?
Marque ( ) posted Fri, 02 February 2007 at 8:29 PM
There is a tutorial on putting clothing on sydney, I will try to find it and give you the link. Pretty sad that the characters that come with p7 aren't able to wear the clothes that are made for them much less stuff that isn't.
Marque ( ) posted Fri, 02 February 2007 at 8:30 PM
Marque ( ) posted Fri, 02 February 2007 at 8:31 PM
Pathetic isn't it?
PhilC ( ) posted Fri, 02 February 2007 at 10:24 PM
You'll need to make minor adjustments to the joint parameters.
Click on the Wardrobe Wizard help button.
That will bring up a web page stored on your hard drive.
Click the link "Joint Parameters On Screen Video"
The specific information you require is about 3/4 into that video.
The adjustments are small, difficult to explain in just text, but much clearer to show in real time on screen.
Hope that helps.
Morgano ( ) posted Sat, 03 February 2007 at 1:46 AM
Thanks.   That did help.   I think that I have eliminated the problem on the legs.   I am having a bit more trouble isolating the problem with the wrists, but I am getting there.   Many thanks for your help.
PhilC ( ) posted Sat, 03 February 2007 at 2:07 AM
With the wrists try simply turning off the spherical fall off zones.
