Sun, Feb 2, 8:04 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
Subject: What is wrong with Wardrobe Wizard in P7?
eportscreations ( ) posted Sat, 03 February 2007 at 3:01 AM · edited Sun, 02 February 2025 at 7:56 AM
Hi,
Anyone know what I'm doing wrong with the wizard? I installed it right because it says in the script menu (PhilC, P7_start_Wardrobe Wizard). I have the  most up to date version, with the P7 update.
Anyway, I click it and get the pop up stating I have to import an OBJ, I do this and del. it  and try to start up the Wizard but end up with the pop up  asking  me to import an OBJ first. I'm in a loop.
I checked PhilC's web site and it just says to do the same thing as above. What  is wrong and  what have I not understood? Any ideas, help.
bladeeport.
PhilC ( ) posted Sat, 03 February 2007 at 3:21 AM
The pop up gives two instructions.
One relates to a work around for a Poser 7 bug. You'll need to import an OBJ file once at the start of your Poser session so that you can manually set the import options.
The second instruction is to use the Poser menu WindowPython scripts to see the script buttons.
There is no reason to continually start the script. Once its started follow the second instruction and open the Python script window.
 Hope this helps.
eportscreations ( ) posted Sat, 03 February 2007 at 3:35 AM
Thank you PhilC,
I understand and have it working now. I was not expecting to get help from the creator himself. Very good service. Thank you.
Bladeeport.
