Wed, Feb 26, 3:56 PM CST
Forum Moderators: RedPhantom
Subject: Animation question
kett ( ) posted Sat, 03 February 2007 at 12:42 AM · edited Wed, 29 January 2025 at 11:35 PM
Does walk path only work with walk designer?
Can we use walk path without using walk designer?
Thank you.
Touchwood ( ) posted Sat, 03 February 2007 at 5:31 AM
As far as I'm aware, the walk path only works with the walk designer.
You can create a walk cycle and save it within the walk designer folder in which case it will show in the WD window for selection, or you can use the walk path as a reference for some other motion in which case you will need to animate the object manually.
lesbentley ( ) posted Sat, 03 February 2007 at 8:23 AM
Q: Does walk path only work with walk designer? A: Yes! Why do you ask? What do you want to do? If you want to animate a prop along a walk path, it can be done by parenting it to a special invisible figure.
kett ( ) posted Sat, 03 February 2007 at 10:06 AM
Thank you, Touchwood, and lesbentley**,
I wanted to move a running horse along a path.
Thank you for the instruction.
How can I save a walk cycle in the walk designer folder?
 Poser6.
Thank you.
jerr3d ( ) posted Sat, 03 February 2007 at 1:18 PM
the walk designer is an amazing thing, although i have not tried it myself, i think it can "walk" the p4 horse in WD you have to load the horse CR2 as the figure type if that does not work well enuf i believe there was some freebies called horsefeathers ? that include horse animation poses or bvh files ?
