Wed, Dec 25, 12:11 AM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: Image size
viper ( ) posted Mon, 29 January 2007 at 6:37 PM · edited Tue, 24 December 2024 at 11:55 AM
I was wondering if anyone had some tips on how to lower image file size without have to make the image itself smaller but still maintaining a crisp image. I use photoshop CS2 and lately I am having problems staying with in RR small size limit but still keeping a decent sized image.
bclaytonphoto ( ) posted Mon, 29 January 2007 at 6:41 PM
Use the "save for web" option
then "optimize to file size"
www.bclaytonphoto.com
bclaytonphoto on Facebook
viper ( ) posted Mon, 29 January 2007 at 7:22 PM
Thanks, I new the option was going to be looking me in the face
vlaaitje ( ) posted Thu, 01 February 2007 at 3:54 AM · edited Thu, 01 February 2007 at 3:54 AM
I use always save as....most of the time I use this size 1100x733
but if you use save for web
you can use the option:
Maxium
very high
high
medium
low
it depends how many KB the image is
if it is more than 512 then USE VERY HIGH
Ilona Krijgsman: My Tree Of Life
gradient ( ) posted Thu, 01 February 2007 at 1:45 PM
Actually, one of the best ways is to use "save for web", select 4-up tab.  It will then show you your image at 4 different levels of compression.
Then....leave the setting on JPEG, maximum.....NOW...adjust the quality setting downwards from 100%.  As you adjust the setting down, the highlighted screen will update to show you your image at that new quality setting.  It will also show you the file size directly underneath that image....so, if you want to get it to 250kb, .....adjust the quality setting downwards until the file size shows 250kb.....then hit SAVE!
In youth, we learn....with age, we understand.
viper ( ) posted Thu, 01 February 2007 at 9:24 PM
yeah it is working out great
TomDart ( ) posted Fri, 02 February 2007 at 9:43 PM
Lower file sizes with the same size upload don't translate into too much degradation on the web..at least the sizes I post.  For forum, an 800 x 600 shot is large enough without introducing much scrolling for the viewer and can easily go to less than 200kb and be fine for viewing.
When a pic is so large it cannot be viewed in the screen of the monitor, scrolling takes bite out of the impact.   So, size to 800 to 900 wide is my suggestion. Panoramas are a different breed and we expect to scroll to see those.    Just my 3 cents worth.       TomDart.
viper ( ) posted Sat, 03 February 2007 at 8:25 AM
@Tomdart, my major problem was getting 800x600 pictures under the 512 restriction photoshop was killing me when I saved them.
