Mon, Jan 6, 8:46 PM CST
Subject: behind the scenes of the diffuse_color node...???
fuaho ( ) posted Mon, 05 February 2007 at 9:27 PM · edited Mon, 06 January 2025 at 8:41 PM
What on earth is going on here?
If you load a two-sided square prop - 2 polys, 8 verts - and render it, you get this off the wall pattern from the diffuse_color node.
Same result and same pattern on both sides of the square.
However, if you use the alternate_diffuse node, it renders a complete square just like one would expect.
Whassup!!??
Tyger_purr ( ) posted Mon, 05 February 2007 at 9:46 PM
Poser/firefly doesn't like double sided polys. apparenly it gets confused as to which side it should be showing. You can fix this by either go to materials and check the "normals forward" box or use one sided square prop.
My Homepage - Free stuff and Galleries
fuaho ( ) posted Mon, 05 February 2007 at 9:55 PM
But it's only with the diffuse_color node.
Alternate_diffuse renders just fine... There's apparently something else going on here.
pjz99 ( ) posted Mon, 05 February 2007 at 10:04 PM
I think that is the secret vampire barcode like they use in the Blade movies.
My Freebies
fuaho ( ) posted Mon, 05 February 2007 at 10:17 PM
That answer really sucks!
ockham ( ) posted Mon, 05 February 2007 at 10:44 PM
Sucky or not, this is definitely typical.  Since v5, Poser has given
this strange barcode or alien checkerboard look for two -sided facets.
It's sort of intermittent and irregular.
Some people have said you can fix it by turning on displacement for the
texture, but it's better to get rid of the two-sided facets.  Either change the
model so it has two actual opposite-facing sides, with a slight space
between, or make it strictly one-sided.
My python page
My ShareCG freebies
Tyger_purr ( ) posted Tue, 06 February 2007 at 9:06 AM
Quote - But it's only with the diffuse_color node.
Its only with double sided polys. Alternate_diffuse is processed in a diffrent way so it's not really a suprise that it looks diffrent.
apply a specular in the alternate_specular and it has the dashes too. a bit more subtle but still there.
Normals_forward seems to work if your not using alternate_ settings.
Pluging a simple color into the displacement and setting it really low (0.0001 or so) seems to fix it every time.
